LAG Port Bandwidth and Throughput
fahad.khan1
If we create LAG on 2504 WLC, so what will be  the throughput of the ports and how much bandwidth would we gain?
Scott Fella
When you create LAG, you have to remember that traffic is symetric and still flow out only one of the bundled ports. So even if you have all four ports bundled, a users traffic will be sent out only one of the gigabit ports. Will this help, sure it can, but it's benefit is redundancy.  I believe the backplane for the 2504 is only a gig also.
-Scott
-Scott
Scott Fella,
I have read same but it o check from my monitoring server other port are also participating. can you explain it further. Its seems like connection with one Access Point is only restrict to one port but it can make connection to other Access point using different port. It my assumption, correct me it i am wrong.
Zohaib
