Bookmark
Subscribe
3999
Cisco AIR-LAP1142N-E-K9 bridge and AP mode configuration
SDiekmeijer
Hi all,
I've got 2x 1142N access points. Both are running autonomous software.
they're both connected to Cisco 3750G's  (SW1 and SW2) in the following way:
SW1 - AP1 >>>> AP2-SW2
I'm trying to accomplish 2 things here:
- The AP's need to bridge the two wired LAN's  on the 5Ghz radio (dot11radio1)
- The AP's should try to advertise the same WLAN for Clients on the 2.4ghz radio (dot11radio0).
What works?
- The AP's bridge on the 5Ghz radio, this works fine. Clients can connect to devices across the bridge.
- Wireless clients can connect to fine to the wlan-client ssid on AP1. At AP2 the Dot11radio0 refuses to come up with different errors:
*Mar  1 07:10:50.825: %DOT11-4-NO_VALID_INFRA_SSID: No infrastructure SSID configured. Dot11Radio0 not started.
03:39:22: DOT11 EVENT:disc_start:Could not configure the radio.
*Mar  1 07:10:50.825: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
03:40:22: DOT11 EVENT:disc_config: root set device to 4D
*Mar  1 07:12:01.902: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response
*Mar  1 07:12:06.912: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Rcvd response from 64d9.896d.cc80 channel 13 2928
I'm using the configuration as per below; anybody got a clue what I'm doing wrong here?
Configuration:
! AP1:
dot11 syslog
dot11 ssid backhaul
   authentication open
dot11 ssid wlan-client
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 0 test
bridge irb
interface Dot11Radio0
 description ; 2.4 Ghz radio
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 ssid wlan-client
 antenna gain 0
 station-role root
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid backhaul
 antenna gain 0
 no dfs band block
 channel dfs
 station-role root bridge
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 bridge-group 1
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
! AP2:
dot11 ssid backhaul
   authentication open
   infrastructure-ssid
   authentication open
   guest-mode
   infrastructure-ssid
   wpa-psk ascii 7 0830747B2C3B34003F3A5A361E032A23313617401711212463
bridge irb
 no ip address
 no ip route-cache
 ssid wlan-client
 antenna gain 0
 station-role non-root wireless-clients
 bridge-group 1
 no ip address
 no ip route-cache
 ssid backhaul
 antenna gain 0
 station-role workgroup-bridge
 bridge-group 1
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 bridge-group 1
interface BVI1
 no ip route-cache
on AP 2 under the Radio 0 it should be "station-role root", not non-root. Sorry I missed that in the config earlier.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
On AP 2 you need to remove the Infrastructure-ssid command under the wlan-client SSID.  That command is for telling the AP that it uses that SSID to connect to another radio.
HTH,
Steve
HTH,
Steve
Hi Steve,
I did that. Then i get the following error:
My SSID configuration is as follows now:
AP2:
dot11 ssid wlan-bb
   authentication open
   infrastructure-ssid
dot11 ssid wlan-hs
   authentication open
   guest-mode
Do you know how to explain that error?
AP1:
dot11 ssid wlan-bb
   authentication open
   infrastructure-ssid
dot11 ssid wlan-hs
   authentication open
   guest-mode
HTH,
Steve
HTH,
Steve
That was it indeed Steve! Many thanks, it works like a charm now :)
