Cisco Aironet 1040 and Radius Auth Failure
ams-it
Beginner
Beginner
Alright now this might seem bizarre but I am really hoping someone can work out what I am doing wrong!
I have setup a Cisco Aironet 1040 to connect to our Radius server which I have also configured.
I can successfully connect up any Iphone or Ipad but I cannot get any laptop to connect.
I have attached the logs showing the Iphone Successfully logging in and the Laptop Failing.
Every single failure in the Event log for NPS comes up with
Network Policy Server denied access to a user.
Contact the Network Policy Server administrator for more information.
User:
    Security ID:            NULL SID
    Account Name:            scottd
    Account Domain:            AMSLAN
    Fully Qualified Account Name:    AMSLAN\scottd
Client Machine:
    Account Name:            -
    Fully Qualified Account Name:    -
    OS-Version:            -
    Called Station Identifier:        5835.d976.9420
    Calling Station Identifier:        d0df.9a92.0f40
NAS:
    NAS IPv4 Address:        192.168.2.98
    NAS IPv6 Address:        -
    NAS Identifier:            ap
    NAS Port-Type:            Wireless - IEEE 802.11
    NAS Port:            336
RADIUS Client:
    Client Friendly Name:        Cisco  AP
    Client IP Address:            192.168.2.98
Authentication Details:
    Connection Request Policy Name:    Secure Wireless Connections
    Network Policy Name:        -
    Authentication Provider:        Windows
    Authentication Server:        AMS-DC3.lan.ams.co.nz
    Authentication Type:        PEAP
    EAP Type:            -
    Account Session Identifier:        -
    Logging Results:            Accounting information was written to the local log file.
    Reason Code:            266
    Reason:                The message received was unexpected or badly formatted.
A successful Iphone connection shows as below
Network Policy Server granted access to a user.
User:
    Security ID:            AMSLAN\scottd
Client Machine:
    Account Name:            -
    OS-Version:            -
    Calling Station Identifier:        dc2b.6196.184b
NAS:
    NAS IPv6 Address:        -
    NAS Identifier:            ap
    NAS Port:            324
RADIUS Client:
    Network Policy Name:        Secure Wireless Connections
    EAP Type:            Microsoft: Secured password (EAP-MSCHAP v2)
Quarantine Information:
    Result:                Full Access
I just cannot for the life of me find any settings or configuration that will allow this to work. I am hoping that someone may have seen this or be able to offer some insight into what could be wrong.
Thanks in advance!
14 Replies 14
ams-it
Beginner
Beginner
Still having this issue if anyone is able to supply any kind of information to point me in the right direction it would be much appreciated!
Yea, i see is doesnt like it ...
Sep 25 23:47:26.884: dot11_auth_dot1x_parse_aaa_resp: Received server response: FAIL
Question, why is the security ID different between the Apple and the laptop?
I wish I knew! The same information is entered but it doesn't seem to send the security ID no matter how I set up the wireless connection on the PC
What supplicant are you using on the laptop ?
I have tried it on both Win XP and WIndows 7 both get the exact same error.
Tried it with and without certificates on, the certificate works as that is what it uses on the Iphones and Ipads
Tried WPA and WPA2 with AES or TKIP
on the Radius setup under NPS if I have any kind of authentication setup I get the
Reason Code:            266
If I set everything to open then it will connect fine so there is no issue with that side of things it's definetly to do with the security used, but whether it is a Cisco AP setting or a windows server/cleint setting eludes me.
read this ... see if this helps at all
http://social.technet.microsoft.com/Forums/en-US/winserverNAP/thread/fc4d949b-7ac5-4c50-b984-4c16b3710716/
From everything I can see this is working correctly as the Iphones use the certificates.
used to have a similar issues on several of our laptops depending on how they were built.
Driver updates fixed our problem though - not sur eif it will for you? but the error was the same for use
I had already given drivers ago, But I tried again anyway. Sadly this didn't fix the problem.
ams-it
Beginner
Beginner
Just tried a Wireless USB stick in multiple hardware and get the exact same issue, peap appears to be the issue but this is what the Iphones say they are connecting with and they work.....
ajamerica
Beginner
Beginner
Was there any updates with this?  I am running into the same issue with 2008 R2 NPS....
jenwilson
Beginner
Beginner
Too many Trusted Auth Certs on the Radius server after update?
See
http://social.technet.microsoft.com/Forums/en-US/winserveressentials/thread/2636b892-7113-4692-a4f4-53d330ca6062
and
http://support.microsoft.com/kb/933430
Method 3 in the above link of adding the regentry SendTrustedIssuerList to 0 fixed the issue for me.
Ivaylo Georgiev
Beginner
Beginner
Scott,
How did you solve this?
Recognize Your Peers
