Cisco aironet 1130 and Intermec CV30
m.contado
Hi to all,
I've a little problem with three Cisco 1130 AP. Anticipately i tell you that i'm not a guru of cisco wireless, but my implementation is very simple. I need a roaming for the 3 AP. I only have Ap, so i configure one as Master Ap and the others like repeater with cisco aironet extension configured. All 3 on the same channel and only the Master one broadcast SSID. Wep security implemented. My Cv30 terminals randomly loose the signal also if they're near an AP. They use windows mobile but i think is only a wrong config problem. I need help. Thank you very much.
Alex
0 Replies 0
