02-23-2016 02:24 AM - edited 07-05-2021 04:39 AM
I want to install a wireless bridge between 2 buildings. I think i want to choice Aironet 1532E with antenna 2.4 Ghz 13-dBi (AIR-ANT2413P2M-N). And i would like to know what is the maximum range between my two points ?
Thanks You.
Solved! Go to Solution.
02-24-2016 12:16 AM
Check out this tool:
Go to the "Coverage" tab.
02-23-2016 06:51 PM
Can I ask a different question. How far apart are the two buildings, and what data rate do you need?
I prefer working on the problem being solved as opposed to finding the question for the answer given.
02-24-2016 12:08 AM
It's a mobile project, for the first step the 2 buildings are close (1km) but for next project it's possible there are 15km between 2 buildings.
I want to have 10Mbps for the bandwith.
Thanks You
02-24-2016 12:16 AM
02-24-2016 12:41 AM
I tested this tool but I haven't had the same results as compared to other tools. Is this tool is reliable?
02-28-2016 03:48 AM
This tool is to give you an idea about what is possible, but can't account for (all) factors specific for your deployment. The only real reliable thing is to perform a site survey and just test with the proposed equipment. Keep in mind the FCC/ETSI regulations and think about lightning resistors if the equipment is mounted somewhere high on the buildings.
Please rate useful posts... :-)
02-29-2016 12:13 AM
Thanks you for all !
