Cisco Aironet 1830 Not Broadcast Default SSID
Reedho
I just bought a Cisco Aironet 1830 with the AIR-AP1832I-F-K9 model. when I will configure the GUI but the SSID not broadcast defaults to the "CiscoAirProvision" broadcast so that I cannot do this configuration.
is there anything that can help so that the device can broadcast the SSID Default
5 Replies 5
Sandeep Choudhary
If it has mobility expres simage then...could you reset AP and try again.:
How:
When you are prompted for a username, enter recover-config to restore the factory default configuration.
Dont forget to rate helpful posts
Leo Laohoo
Maybe the AP is loaded with Mobility Express firmware.
patschka.sascha
Hy
I have the same problem. I have bought two Aironet AP1832I-E-K9.
I have a Smart Switch with POE on a normal Asus Router and the AP1832 connected with the Switch.
After the boottime the green->red->amber led cycling but i can't see the "CiscoAirProvision" SSID if i search for WLANs.
But i cant use the console now, i am not able to connect (maybe my converter is broken ;-( and i must order a new one)
I hope someone can help me to connect with the AP.
Thanks in advanced.
Sascha
Thanks for your reply.
Without a connection via console there ist no chance?
