Cisco Aironet 1832i Firmware Upgrade
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-16-2021 10:14 AM - edited 07-16-2021 11:32 AM
We have a Cisco Aironet 1832i access point. It has 8.2 firmware version and we tried to update to 8.10. Is it possible to update from 8.2 to 8.10 directly?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-16-2021 04:03 PM
If you are referring to the AP only yes it is possible. You can download the code from Cisco software portal and upload to the AP using tftp, as I can remember this code supports only tftp. You need to have console access to the AP as well.
archive download-sw tftp://<path/filename>
But if you have a controller the process might differ, if this is the case you can post your controller information+Ap models managed by WLC to provide further info.
TAC recommended codes for AireOS WLC's
Best Practices for AireOS WLC's
TAC recommended codes for 9800 WLC's
Best Practices for 9800 WLC's
Cisco Wireless compatibility matrix
___________________________________________
Arshad Safrulla
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-18-2021 04:22 AM
For WLC check the guide in the release notes https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn810mr5.html#upgrade-software
For Mobility Express https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810/getg_started.html#task_7588F4C009744AEFBB9EB754A713E390 or https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810/appendix.html#task_330D7AD89F974001BEF10985059485DF
ME can be very temperamental so may be better/easier to convert back to standard CAPWAP AP then upgrade to new ME code.
Please click Helpful if this post helped you and Select as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's and TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's, Best Practices for 9800 WLC's and Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
