Cisco Aironet 2600 WAP MCS Rates
Peter Talas
I'm hoping my question has an easy answer, so here it is:
We've got 3 Aironet 2600 Access points set up as access points with a radius server.  Encryption is aes-ccm, authentication is open+EAP and key management is wpa, no VLAN.  As of now, we are only getting 54Mbps on the 2.4 and 5 GHz radios.  I wanted to take advantage of the MCS rates, so I enabled World Mode Multi-domain operation (Dot11d, US, indoor) and then tried to enable the MCS rates.  I'm doing this via the web interface since this is the only way I know how to modify the config.  The issue is that I cannot apply the MCS rate changes.  When I hit apply, nothing happens.  Any other change I make applies to the wap without issue (e.g. WMM was fine).  I thought it might have been a browser issue, so I went on an old server 2000 box with IE6 installed.  This made no difference.  The same happened when I ran it off Firefox 2 (another supported browser).
Does anyone know why the MCS rates will not apply?  I'm guessing I'll need to provide more info, but any and all help is much appreciated.
Enable mcs data rate as per this document:
interface Dot11Radio0 or dot11radio1
no ip address
no ip route-cache
ssid myssid
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m8. m9. m10. m11. m12. m13. m14. m15.
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/15_2_4_JB/configuration/guide/scg15_2_4_JB3a.pdf
Dont forget to rate ehlpful posts
7 Replies 7
Rasika Nayanajith
WLAN Security Setting should be WPA2 policy with AES encryption (do not enable WPA).
In addition to this settting you required to enable WMM (either Allow or Required under WLAN > QoS setting) in order to get 802.11n/802.11ac (or MCS) data rates.
Rasika
*** Pls rate all useful responses ***
Thanks for the quick response, Manannalage.  It looks like I have WMM enabled for both radios under QoS.  AES CCMP is enabled as the cipher under encryption modes, but where would I set the WPA2 policy?  When I'm looking at my config, I see authentication key-management wpa version 2.  Is that not where i should be looking?  Here's my current config:
! Last configuration change at 11:03:54 -0500 Mon Dec 7 2015 by user
! NVRAM config last updated at 11:03:54 -0500 Mon Dec 7 2015 by user
version 15.2
no service pad
service password-encryption
hostname mywap
logging rate-limit console 9
aaa new-model
aaa group server radius rad_eap
 server x.x.x.x auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa group server radius rad_eap2
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods2 group rad_eap2
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone -0500 -5 0
clock summer-time -0400 recurring
no ip routing
dot11 syslog
dot11 ssid Wireless
   authentication open eap eap_methods2
   guest-mode
dot11 network-map
dot11 arp-cache optional
username myuser privilege 15 password 7 101D08140C101D18
username myuser2 password 7 00364002170B13545F7019
bridge irb
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 ssid myssid
 antenna gain 0
 stbc
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
 station-role root
 world-mode dot11d country-code US indoor
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid my ssid
 antenna gain 0
 dfs band 3 block
 stbc
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
 channel width 40-above
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address x.x.x.x  x.x.x.x
 no ip route-cache
ip default-gateway x.x.x.x
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.100.1.51 auth-port 1812 acct-port 1813 key 7
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
 transport input all
sntp server x.x.x.x
sntp broadcast client
end
no ip address
no ip route-cache
ssid myssid
Thanks, Sandeep.
When I try to apply those settings in the web interface (hit apply), nothing happens.  If i try to telnet into the wap and set them as you have linked and show me here, it appears to be working but when I show the config, it is still set to basic rates only.
Am I missing something else in my config above that would prevent the MCS rates from enabling properly?
Config is correct except zour basic rates under interface configuration.
GUI of autonomous AP is normally very slow so better to use cLI to configure it.
*** If still fails to get 802.11n rates then try to create a open ssid and check it.
Dont forget to rate helpful posts
Looks good now, Sandeep.  Thank you for the quick and helpful assistance.
hello, how was this resolved? i am having the same issues with a 2602 AP. i am unable to get N speeds and have tried enabling MCS but i am unable to 'apply' changes using the GUI. i am also unable to apply WMM. i try to hit Dot11d and indoor, but it asks me for a country code, but nothing comes up in the dropdown? apologies but i am not familiar with CLI too much and have been trying to figure this out using the GUI. many thanks in advance!
