Cisco Aironet 2702 AP and repeater
Guillaume-fr
Hello, I'm facing an issue setting up a RootAP(With DHCP) and a Repeater.
When I connect a wireless device to my RootAP (192.168.1.240), no problem, is authenticates, gets and IP, and reaches what is behind the ethernet port (192.168.1.10 for example).
But, when I connect to the Repeater (192.168.2.241), it Authenticates, gets an IP (from the root ?!), but after that, no way to ping the root AP
Here are the configs
---------AP
Current configuration : 2182 bytes
! Last configuration change at 00:27:54 UTC Mon Mar 1 1993
version 15.3
no service pad
service password-encryption
hostname AP1
logging rate-limit console 9
enable secret 5 $1$ncXR$aJ89XNhrxXBxXHBOnTnoE/
no aaa new-model
no ip source-route
no ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool Wifi
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 192.168.1.254
dot11 pause-time 100
dot11 syslog
dot11 ssid Aittouassel
authentication open
authentication key-management wpa version 2
guest-mode
infrastructure-ssid
wpa-psk ascii 7 047803031A22441F5B45
no ipv6 cef
username Cisco password 7 56300F180804
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid Aittouassel
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 002a.106e.801c
ip address 192.168.1.240 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
-----------------Repeater
Current configuration : 2048 bytes
! Last configuration change at 00:09:54 UTC Mon Mar 1 1993
version 15.3
no service pad
hostname AP2
enable secret 5 $1$FN4G$mwTWu9LXDIg4LosGs62jH.
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
authentication open
guest-mode
infrastructure-ssid
wpa-psk ascii 7 13261F171E0F0C7B7977
no ipv6 cef
username Cisco password 7 096F471A1A0A
bridge irb
no ip address
ssid Aittouassel
antenna gain 0
parent 1 843d.c6d5.9c60
station-role repeater
bridge-group 1
no ip address
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
duplex auto
speed auto
bridge-group 1
no ip address
shutdown
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 0081.c48e.c740
ip address 192.168.1.241 255.255.255.0
ipv6 address dhcp
ipv6 enable
no ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
To resume my topology :
Cli1-- Ethernet -- AP1(Dhcp) -- AP2 -- Cli2
Ping Cli1 AP2 - OK
Ping CLI2 AP1 - KO
Thanks for your help !
0 Replies 0
