Cisco Aironet Outdoor Wireless Bridge
kasimalbayrak
Hi all,
We are able to receive 54 mbps bandwith wireless bridge with Cisco aironet 1310 series devices.
There is a need for 1 Gbps bandwith.
Do you share the device recommendation for running aironet wireless bridge.
good work...
thanks in advance for your shares
balaji.bandi
balaji.bandi
here is the models with comparision :
https://www.cisco.com/c/en/us/products/wireless/outdoor-wireless/product-comparison.html
BB
Thanks, BB.
Mikey Boy
Realistically if you are wanting a true 1Gbps bridge solution you need to look at a product specifically designed for this.
There are a number of vendors that can do this, I have used Siklu and ubiquiti in the past.
They will use proprietary protocols to achieve this and will most likely be away from the 2.4 and 5Ghz bands.
mikey,
Thank you for sharing, my research. :)
