Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco AP 1042N Can not join a controller
fgasimzade
Level 4
Level 4
We have purchased new 1042 Access-points, and we already have a cisco 3750 integrated wireless controller with 7.0.220.0 software
An access point have received the IP address, has found the controller, downloaded firmware and now fails to register with this messages is concole
*Feb  9 07:43:23.351: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb  9 07:43:23.443:  status of voice_diag_test from WLC is false
*Feb  9 07:43:33.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 192.168.110.82 peer_port: 5246
*Feb  9 07:43:33.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb  9 07:43:34.158: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 192.168.110.82 peer_port: 5246
*Feb  9 07:43:34.159: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.110.82
*Feb  9 07:43:34.159: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb  9 07:43:34.298: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Feb  9 07:43:34.302: %DTLS-5-ALERT: Received WARNING : Close notify alert from
192.168.110.82
*Feb  9 07:43:34.302: %DTLS-5-PEER_DISCONNECT: Peer 192.168.110.82 has closed co
nnection.
*Feb  9 07:43:34.303: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192
.168.110.82:5246
Can it be due to incompatible regulatory domain? Controller is -A, access point is -E
Leo Laohoo
That's correct.
14 Replies 14
Leo Laohoo
That's correct.
fgasimzade
Level 4
Level 4
Ok, I have changed Contry config on the Controller, now seems like AP has joined it, but Admin Status is DISABLED
Any ideas?
Check if your radios are disabled or not.
Are you using PoE?
Yes, I am using PoE
I have manually enabled interfaces on AP, seems like they are UP now, a can see SSID are broadcasted, but I can not associate with them anyway. An after restart interfaces on AP are still down
Can you please try with OPEN authentication?
Yes, I am trying with an OPEN authentication, my Blackberry fails to associate.
And what about shutted down radio interfaces? Any thoughts?
Thank you for your help!
Please paste the following outputs
WLC
Show country
AP
show ip int brief
show controllers d1
show controller d0
more flash:event.log
NikhiL
Regulatory Domain on WLC is -AER
AP2894.0fd6.c264#sh ip interface brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
Dot11Radio0                unassigned      NO  unset  administratively down down
Dot11Radio1                unassigned      NO  unset  administratively down down
GigabitEthernet0           192.168.110.8   YES DHCP   up                    up
AP2894.0fd6.c264#sh controllers d1
interface Dot11Radio1
Radio AIR-AP1140A, Base Address 1caa.0770.2aa0, BBlock version 0.00, Software ve
rsion 3.00.81
Serial number: FOC15123GN8
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: ETSI (OFDM) (EU) (-E)
Uniform Spreading Required: Yes
Configured Frequency: 5700 MHz  Channel 140 (DFS enabled)
Allowed Frequencies: 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(
60) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5660(132) 5680(13
6) 5700(140)
Listen Frequencies: 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(6
0) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5600(120) 5620(124
) 5640(128) 5660(132) 5680(136) 5700(140) 5745(149) 5765(153) 5785(157) 5805(161
) 5825(165)
Beacon Flags: 0, Interface Flags 60109, Interface Events 0, Mode 9; Beacons are
disabled; Probes are disabled
Configured Power: 17 dBm (level 1)
AP2894.0fd6.c264#sh controllers d0
interface Dot11Radio0
Radio AIR-AP1140G, Base Address 1caa.0743.f160, BBlock version 0.00, Software ve
rsion 3.00.81
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set: EMEA (EU) (-E)
Uniform Spreading Required: No
Configured Frequency: 2462 MHz  Channel 11
Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 244
7(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13)
Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447
(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14)
Configured Power: 5 dBm (level 5)
Active power levels by rate
     1.0 to 54.0-d, 5   dBm
  OffChnl Power: 16, Rate 1.0
Allowed Power Levels:  -1 2 5 8 11 14 17
Allowed Client Power Levels: 2 5 8 11 14 17
Receive Antennas : right-a left-b
Transmit Antennas : right-a left-b, cck single, ofdm all
Antenna: internal, Gain: Allowed 8, Reported 0, Configured 0, In Use 8
AP2894.0fd6.c264#more flash:event.log
*Feb 9 08:00:48.001: %CAPWAP-3-EVENTLOG: Choosing AP Mgr with index 0, IP = 0xC0
A86E52, load = 7..
*Feb 9 08:00:48.001: %CAPWAP-3-EVENTLOG: Synchronizing time with AC time.
*Feb 9 08:00:48.002: %CAPWAP-3-EVENTLOG: Setting time to 08:00:48 UTC Feb 9 2012
*Feb 9 08:00:48.002: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip
*Feb 9 08:00:48.002: %CAPWAP-3-EVENTLOG: CAPWAP State: DTLS Setup.
*Feb 9 08:00:48.002: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 9 08:00:49.162: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Feb 9 08:00:49.163: %CAPWAP-3-EVENTLOG: Dtls Session Established with the AC 19
2.168.110.82,port= 5246
*Feb 9 08:00:49.163: %CAPWAP-3-EVENTLOG: CAPWAP State: Join.
*Feb 9 08:00:49.163: %CAPWAP-3-EVENTLOG: Join request: version=117496832
*Feb 9 08:00:49.163: %CAPWAP-3-EVENTLOG: WTP descriptor: version=117496832
*Feb 9 08:00:49.163: %CAPWAP-3-EVENTLOG: Join request: hasMaximum Message Payloa
d
*Feb 9 08:00:49.163: %CAPWAP-3-EVENTLOG: Sending Join Request Path MTU payload,
Length 1376
*Feb 9 08:00:49.163: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.110.82
*Feb 9 08:00:49.163: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: Join Response from 192.168.110.82
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: PTMU : Setting MTU to : 1485
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: Starting Post Join timer
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: CAPWAP State: Configure.
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: reboot reason flag 21
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: Configuration Status sent to 192.168.11
0.82
*Feb 9 08:00:49.303: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Feb 9 08:00:49.303: %CAPWAP-3-EVENTLOG: Current image is good. Connecting to th
e controller.
*Feb 9 08:00:49.309: %DTLS-5-ALERT: Received WARNING : Close notify alert from 1
92.168.110.82
*Feb 9 08:00:49.404: %CAPWAP-3-EVENTLOG: Ignoring callback message Close alert r
eceived..
*Feb 9 08:00:49.411: %DTLS-5-PEER_DISCONNECT: Peer 192.168.110.82 has closed con
nection.
*Feb 9 08:00:49.413: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.
168.110.82:5246
*Feb 9 08:00:49.449: %CAPWAP-3-EVENTLOG: DTLS session cleanup completed. Restart
ing capwap state machine.
*Feb 9 08:00:49.449: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 9 08:00:49.450: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to ad
ministratively down
*Feb 9 08:00:49.450: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to ad
ministratively down
*Feb 9 08:00:49.450: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
nnel and power levels info.192:168:110:82
*Feb 9 08:00:49.450: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 9 08:00:49.450: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to re
set
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: Starting Discovery.Initializing discove
ry latency in discovery responses
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: CAPWAP State: Discovery.
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: WTP descriptor: version=117496832
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: Discovery Request sent to 192.168.254.8
1 with discovery type set to 3
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: Discovery Request sent to 255.255.255.2
55 with discovery type set to 0
*Feb 9 08:00:49.451: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 9 08:00:49.451: %CAPWAP-3-EVENTLOG: Discovery Response from 192.168.254.81
*Feb 9 08:00:49.457: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:00:49.458: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 9 08:00:49.470: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to re
set
*Feb 9 08:00:49.483: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:00:49.484: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: Selected MWAR 'Cisco_68:60:c7' (index 0
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: Ap mgr count=1
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: Go join a capwap controller
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: Choosing AP Mgr with index 0, IP = 0xC0
A86E52, load = 7..
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: Synchronizing time with AC time.
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: Setting time to 08:01:00 UTC Feb 9 2012
*Feb 9 08:01:00.002: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip
*Feb 9 08:01:00.002: %CAPWAP-3-EVENTLOG: CAPWAP State: DTLS Setup.
*Feb 9 08:01:00.002: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 9 08:01:01.159: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Feb 9 08:01:01.159: %CAPWAP-3-EVENTLOG: Dtls Session Established with the AC 19
*Feb 9 08:01:01.159: %CAPWAP-3-EVENTLOG: CAPWAP State: Join.
*Feb 9 08:01:01.159: %CAPWAP-3-EVENTLOG: Join request: version=117496832
*Feb 9 08:01:01.159: %CAPWAP-3-EVENTLOG: WTP descriptor: version=117496832
*Feb 9 08:01:01.159: %CAPWAP-3-EVENTLOG: Join request: hasMaximum Message Payloa
d
*Feb 9 08:01:01.159: %CAPWAP-3-EVENTLOG: Sending Join Request Path MTU payload,
Length 1376
*Feb 9 08:01:01.159: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.110.82
*Feb 9 08:01:01.159: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: Join Response from 192.168.110.82
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: PTMU : Setting MTU to : 1485
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: Starting Post Join timer
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: CAPWAP State: Configure.
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: reboot reason flag 21
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: Configuration Status sent to 192.168.11
0.82
*Feb 9 08:01:01.298: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Feb 9 08:01:01.298: %CAPWAP-3-EVENTLOG: Current image is good. Connecting to th
e controller.
*Feb 9 08:01:01.304: %DTLS-5-ALERT: Received WARNING : Close notify alert from 1
92.168.110.82
*Feb 9 08:01:01.399: %CAPWAP-3-EVENTLOG: Ignoring callback message Close alert r
eceived..
*Feb 9 08:01:01.406: %DTLS-5-PEER_DISCONNECT: Peer 192.168.110.82 has closed con
nection.
*Feb 9 08:01:01.407: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.
168.110.82:5246
*Feb 9 08:01:01.443: %CAPWAP-3-EVENTLOG: DTLS session cleanup completed. Restart
*Feb 9 08:01:01.443: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 9 08:01:01.443: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to ad
ministratively down
*Feb 9 08:01:01.443: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to ad
ministratively down
*Feb 9 08:01:01.444: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:01:01.444: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to re
set
*Feb 9 08:01:01.444: %CAPWAP-3-EVENTLOG: Starting Discovery.Initializing discove
*Feb 9 08:01:01.444: %CAPWAP-3-EVENTLOG: CAPWAP State: Discovery.
*Feb 9 08:01:01.444: %CAPWAP-3-EVENTLOG: WTP descriptor: version=117496832
*Feb 9 08:01:01.444: %CAPWAP-3-EVENTLOG: Discovery Request sent to 192.168.254.8
*Feb 9 08:01:01.445: %CAPWAP-3-EVENTLOG: WTP descriptor: version=117496832
*Feb 9 08:01:01.445: %CAPWAP-3-EVENTLOG: Discovery Request sent to 255.255.255.2
*Feb 9 08:01:01.445: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 9 08:01:01.445: %CAPWAP-3-EVENTLOG: Discovery Response from 192.168.254.81
*Feb 9 08:01:01.450: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:01:01.451: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 9 08:01:01.463: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to re
set
*Feb 9 08:01:01.476: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:01:01.477: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Feb 9 08:01:12.001: %CAPWAP-3-EVENTLOG: Selected MWAR 'Cisco_68:60:c7' (index 0
*Feb 9 08:01:12.001: %CAPWAP-3-EVENTLOG: Ap mgr count=1
*Feb 9 08:01:12.001: %CAPWAP-3-EVENTLOG: Go join a capwap controller
*Feb 9 08:01:12.001: %CAPWAP-3-EVENTLOG: Choosing AP Mgr with index 0, IP = 0xC0
A86E52, load = 7..
*Feb 9 08:01:12.001: %CAPWAP-3-EVENTLOG: Synchronizing time with AC time.
*Feb 9 08:01:12.002: %CAPWAP-3-EVENTLOG: Setting time to 08:01:12 UTC Feb 9 2012
*Feb 9 08:01:12.002: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip
*Feb 9 08:01:12.002: %CAPWAP-3-EVENTLOG: CAPWAP State: DTLS Setup.
*Feb 9 08:01:12.002: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 9 08:01:13.162: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Feb 9 08:01:13.162: %CAPWAP-3-EVENTLOG: Dtls Session Established with the AC 19
*Feb 9 08:01:13.162: %CAPWAP-3-EVENTLOG: CAPWAP State: Join.
*Feb 9 08:01:13.162: %CAPWAP-3-EVENTLOG: Join request: version=117496832
*Feb 9 08:01:13.163: %CAPWAP-3-EVENTLOG: WTP descriptor: version=117496832
*Feb 9 08:01:13.163: %CAPWAP-3-EVENTLOG: Join request: hasMaximum Message Payloa
d
*Feb 9 08:01:13.163: %CAPWAP-3-EVENTLOG: Sending Join Request Path MTU payload,
Length 1376
*Feb 9 08:01:13.163: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.110.82
*Feb 9 08:01:13.163: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: Join Response from 192.168.110.82
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: PTMU : Setting MTU to : 1485
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: Starting Post Join timer
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: CAPWAP State: Configure.
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: reboot reason flag 21
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Feb 9 08:01:13.302: %CAPWAP-3-EVENTLOG: Configuration Status sent to 192.168.11
0.82
*Feb 9 08:01:13.302: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Feb 9 08:01:13.303: %CAPWAP-3-EVENTLOG: Current image is good. Connecting to th
e controller.
*Feb 9 08:01:13.308: %DTLS-5-ALERT: Received WARNING : Close notify alert from 1
92.168.110.82
*Feb 9 08:01:13.403: %CAPWAP-3-EVENTLOG: Ignoring callback message Close alert r
eceived..
*Feb 9 08:01:13.409: %DTLS-5-PEER_DISCONNECT: Peer 192.168.110.82 has closed con
nection.
*Feb 9 08:01:13.410: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.
168.110.82:5246
*Feb 9 08:01:13.447: %CAPWAP-3-EVENTLOG: DTLS session cleanup completed. Restart
*Feb 9 08:01:13.447: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 9 08:01:13.447: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to ad
ministratively down
*Feb 9 08:01:13.447: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to ad
ministratively down
*Feb 9 08:01:13.447: %CAPWAP-3-EVENTLOG: CAPWAP state not up.  Abort sending cha
*Feb 9 08:01:13.447: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to re
set
AP2894.0fd6.c264#
Can you disable the A and R domains in the wireless controller, if not required
I can disable R, but we've got A for other APs
One more thing, when I manually no shutdown interfaces on AP, I still get Admin Status Disabled on Controller
I also get
NVRAM Verification Failed
when I try to save config
Thank you guys for your help, I enabled Admin Status from the WLC, everything works fine now!
Happy to see that the issue was resolved
