Cisco AP 1142
saroj pradhan
the is one  issue i see in the Log  of the AP  when the user  report  frequent disconnect  of  the wifi on his laptop.
*Nov 30 04:34:50.176: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0026.b6ee.9406 Reason: Sending station has left the BSS
*Nov 30 04:34:50.203: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   0026.b6ee.9406 Associated KEY_MGMT[WPA PSK]
please help what is the issue.
Saroj Pradhan
30 Replies 30
Your using pre shared keys for the SSID so why do you have AAA defined and also your using Mac filter. Have you tried to start of with a simple configuration and see if that works and then add more to see where it fails?
-Scott
