Cisco AP 1142
saroj pradhan
the is one  issue i see in the Log  of the AP  when the user  report  frequent disconnect  of  the wifi on his laptop.
*Nov 30 04:34:50.176: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0026.b6ee.9406 Reason: Sending station has left the BSS
*Nov 30 04:34:50.203: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   0026.b6ee.9406 Associated KEY_MGMT[WPA PSK]
please help what is the issue.
Saroj Pradhan
30 Replies 30
I don't think that is possible with autonomous. And if everyone is on the same vlan, you might as well just have one vlan. The reason for multiple SSID's is to be able to place traffic in certain vlans so you can control traffic with ACL's, filter or whatever. It's also used at time for QoS purposes. So in your case if you don't want to create multiple vlans, then just stick with a single SSID. If you had a WLC you would be able to do what you wanted.
-Scott
I dont have WLC to controll .  Actually  i  30 -35  users to access the WAP  for which  i wanted to  loadbalance users with  different SSID in the same VLAN.  If not then any other way  so that  the users will no face problem of wap disconnect.
i am using MAC Addess Filter  for authentication also.
Saroj
Having multiple SSID's doesn't load balance anything since they are all still associated to the access point. If your having issues with clients being disassociated, then I would look at other things like interference, client drivers, etc.
-Scott
Can you please clear on Interferace  .
Saroj
Well interference can affect the wireless in general but most of the time on the 2.4ghz. Reading this thread, if its a single user really complaining, then I would look at that users laptop. Make sure the driver is the latest version, make sure that the wireless adapter configuration is default and not been changed around. If you had a wireless issue, it would be affecting most or all of the users.
-Scott
There are  two  WAP ( AP 1142 and AP 441N) in the  same building   in a  distance  of  20feets  distance . Can it  conflict  with the singnal of the WAP ?  I found some times the WAP  441N goes down .
Saroj
Well when the WAP 441N goes down, then users will drop... there is no true roaming with stand alone access points so maybe just leave the 441N off and see if that helps.  I'm also assuming that the SSID's are identical on both AP's?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yes  the SSID's   are  identical   on both AP's.
Will check when 441n will off.
Thanks  for the  valuable  Informations  sharing with me  in all our conversations.
Saroj
Not something to do with the users laptop and power save perhaps?
Sounds like a client device/driver issue as the other chaps say.
What's the roaming aggressiveness set to on the client? Have you ruled out that the client isn't flipping between two access points?
i have  monitor the  cisco AP1142 and  found  that  after  some  intervals  of time   all the users disconnected  from the WiFi connection.i have  tested with two  laptops  and  run  same ping test on both the LAPTOP'S and found  discinnected   after  30-45 minutes.
Please advice.
Saroj
This is tough to troubleshoot. So did you shut off the other AP? The clients have updated driver? How many wireless profiles does the client device have? When a client is disconnected does that mean its not connected on the wireless or it gets a 169.x.x.x address?
-Scott
Also, post your configuration so we am see if its configured right.
-Scott
Can you answer some of these questions?
-Scott
please find the configuration of the AP.
AP-5THFLOOR#sh run
Building configuration...
Current configuration : 7759 bytes
version 12.4
no service pad
service password-encryption
hostname AP-5THFLOOR
enable secret 5 $1$RVWs$meF4BtzKGLlLWrs48nRWp.
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone +0530 5 30
ip domain name NSGBPL-AP.netlink.com
ip name-server 172.16.48.146
ip name-server 172.16.48.147
dot11 association mac-list 700
dot11 syslog
dot11 ssid NSG-User
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 082F195A05400B46432B1E543F7A713A
dot11 ssid NSGBPL
   authentication open
   guest-mode
   wpa-psk ascii 7 151C5E18087325757913277206564311
dot11 arp-cache
username Cisco password 7 047802150C2E
username sarojp privilege 15 password 7 045558125C2F4B1E5B
username 9439e5e6a7cf password 7 154B5F5F5D2F7E217E32622115
username 9439e5e6a7cf autocommand exit
username deepak privilege 15 password 7 12090404011C03162E7F60
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid NSG-User
ssid NSGBPL
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-below
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid NSG-User
ssid NSGBPL
antenna gain 0
no dfs band block
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
