Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco AP 1242 IOS and Antenna
The_guroo_2
Level 2
Level 2
Gents just a quick question regarding Cisco AP 1242......which is the recommended IOS for 1242 to make it autonomous AP. Secondly i got the new AP  and to my surprise when i open it i cant find any Antenna with it. My question is that will it work without Antenna secondly what antenna should i buy keeping in mind that i will be making it standalone Ap with ADSL router heard that they have different Antennas
Kindly help
2 Accepted Solutions
So why would cisco sell Ap without antenna this is very starnge as per your say it will not work which is very starnge......
It ain't strange.  It's logic.  How would Cisco know what antenna you, as a customer, want?
I am setting this AP as autonomus and will hook up with ADSL modem so kindly advise the Antenna's shd i but all four.
I've given you the part numbers and I've given you the document link.  It's now your job to choose which one you want.  For a single 1240, you would ideally need two 2.4 Ghz and two 5.0 Ghz antenna.  You can optionally disable either one of the radios and/or optionally disable Diversity.
huge two story house keeping in mind that Ap will be at ground floor
What are the floors made of?  Wood?  Concrete?
My recommendation:
1.  Install the AP hanging off the ground floor ceiling; or
2.   Get two 1240.
Thanks for taking the time to rate our posts.
8 Replies 8
Leo Laohoo
No.
Articulated (AIR-ANT2422SDW-R & AIR-ANT5135D) or non-articulated rubber duck (AIR-ANT2422D or AIR-ANT4941 & AIR-ANT5135DG-R) or rubber duckie (AIR-ANT2422DG-R & AIR-ANT5135SDW-R)  antennas would suffice.  It all boils down how you install the AP.
Go here.
NOTE:  Please do NOT be tempted to get the high-powered "disco sticks" if the AP is going to be used at home.
it has four anntenna so i need max coverage..........i saw that above ones are 5ghz and bottom ones are 2.4ghz
I am setting this AP as autonomus and will hook up with ADSL modem so kindly advise the Antenna's shd i but all four............or i cant buy four how does teh configuration work
Ok one last thing............I have checked teh antenna types and it cost $$$$............what would you recommend for a huge two story house keeping in mind that Ap will be at ground floor and current wirless (normal router) signals are very bad at upper story...........how many and which ones
Thanks heaps
My recommendation:
2.   Get two 1240.
last one i promise....i am getting nuts i saw these two antenas everything is same expect the size of it..........my question is that if its same why would they market one smaller and one bigger antenna everything is same..........shd i go for wither one or is there any difference
2.2 dBi Dipole
AIR-ANT2422DW-R
Dimensions and Mounting Specifications
Azimuth Plane Radiation Pattern
Elevation Plane Radiation Pattern
Frequency Range
2.4-2.484 GHz
VSWR
Less than 2:1
Power
5 watts
Gain
2.2 dBi
Polarization
Linear
Azimuth 3dB Beamwidth
Omnidirectional
Elevations 3dB Beamwidth
65 degrees
Antenna Connector
RP-TNC
Cable Length
None
Dimensions
5.5 in.
Mounting
To RP-TNC Connector
2.2 dBi Dipole
AIR-ANT2422DG-R
Frequency Range
2.4-2.484 GHz
VSWR
Less than 2:1
Power
5 watts
Gain
2.2 dBi
Polarization
Linear
Omnidirectional
65 degrees
Antenna Connector
RP-TNC
Cable Length
None
Dimensions
3.9 in.
Mounting
To RP-TNC Connector
AIR-ANT2422D
This is an articulated (aka bend-able or foldable) antenna.
AIR-ANT2422DG
Non-articulated and rigid.
Both have same power but the AIR-ANT2422DG is newer.
Depends on how you want to install your 1240.  If the 1240 is mounted flat on the wall, then AIR-ANT2422DG would be suffice.   IF you are able to mount the AP from the ceiling (Cisco logo facing the floor), then you can use the articulated antenna and point the antenna towards the floor.
Just want to let you know the non-articulated antenna comes in one color.  The articulated antenna comes in white (AIR-ANT2422DW) and black (AIR-ANT2422DB).  Black "blends" well with your 1240.
Abhishek Abhishek
Yes, it will surely work but keep in mind the placement of the antennas.
