ā09-09-2014 01:45 AM - edited ā07-05-2021 01:29 AM
we are using AIR-AP1242AG-A-K9 but from past few days it is showing limited connectivity to users and sometimes users are not able to connect.
what can be exact solution for this?
ā09-10-2014 11:47 AM
Try resetting to factory defaults and check if that helps.
You can reset the AP to factory defaults either from the controller or manually.
To clear the controller's configuration, choose Commands > Reset to Factory Default > Reset on the controller GUI, or enter the clear config command on the controller CLI. To clear the access point's configuration, enter the clear ap config Cisco_AP command on the controller CLI.
You can manually reset your access point to default settings using this EXEC mode CLI command:
Note This command requires the controller configured Enable password to enter the CLI EXEC mode.
clear lwapp private-config
Hope that helps.
ā09-30-2014 11:04 PM
Hello Moin,
Thank you for the reply.
but factory reset and config erase also didn't help. Any alternative solution you can suggest on this?
ā10-01-2014 02:32 PM
Which IOS version running on your AP ? If there is any latest image for this AP model you can try upgrading the image & see.
Rasika
**** Pls rate all useful responses ****
ā10-01-2014 09:31 PM
Just did that and kept under monitring.Will update once i get any upadte. Thanks.
ā10-01-2014 10:20 PM
Hope that will work.
If so you can mention the code you upgraded for others benefit & mark this thread as answered.
Rasika
ā01-23-2015 01:45 PM
Upgarde the IOS of your AP to the latest code and then check.
