09-20-2017 10:53 AM - edited 07-05-2021 07:40 AM
Hi guys,
I have Cisco AP outdoor 1552E and I connected with switch and power cord for power... I see RF-1 LED not working and can not see it in the WLC!
What could be the problem?
Actually I worked with this model before and work fine after connected with power. but in this case doesnt work!
Mohammad
Solved! Go to Solution.
09-20-2017 11:30 PM
No problem. So you are definitely in Autonomous mode:
System image file is "flash:/c1520-k9w7-mx.152-2.JB/c1520-k9w7-xx.152-2.JB"
Try a show flash to see if there is a k9w8 image which is possible but otherwise you will need to download a lightweight image and upgrade the image manually:
Assuming you use TFTP for example it is as simple as:
archive download-sw tftp://<ip address>/<file name> flash:
[Confirm]
e.g. archive download-sw tftp://10.1.2.3/c1550-k9w8-tar.153-3.JF.tar flash:
Reload once downloaded and it will boot into LW mode.
Ric
09-20-2017 10:43 PM
I telnet inside one of AP 1552E and I saw this:
show ver
cisco AIR-SAP1552E-M-K9 (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1837H04N
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power loss
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 1C:DE:A7:DE:4D:A0
Part Number : 73-13538-02
PCA Assembly Number : 800-31224-01
PCA Revision Number : 03
PCB Serial Number : FOC18323903
Top Assembly Part Number : 800-34853-05
Top Assembly Serial Number : FCZ1837H04N
Top Revision Number : A0
Product/Model Number : AIR-CAP1552E-M-K9
the product name is AIR-CAP1552E-M-K9 and here is mention differenet cisco AIR-SAP1552E-M-K9 (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Is i a proble and need to change the FW?
09-20-2017 11:06 PM - edited 09-20-2017 11:06 PM
So it receives an IP as you can telnet on to it.
Do you see AP Join logs on the 1552E?
Do you see AP Join logs on the Cisco WLC?
Can you do a show sysinfo and show country on your WLC?
Ric
09-20-2017 11:13 PM
AP cannot see the wlc!
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.122.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... MTHL_WLC_1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.80.18.6
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 7 days 16 hrs 1 mins 28 secs
System Timezone Location......................... (GMT +3:00) Baghdad
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... SA - Saudi Arabia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +45 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 14
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ F8:C2:88:8C:4B:40
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
System Nas-Id.................................... MTHL_WLC_1
WLC MIC Certificate Types........................ SHA1
--More-- or (q)uit
(Cisco Controller) >show country
Configured Country............................. SA - Saudi Arabia
Configured Country Codes
SA - Saudi Arabia.............................. 802.11a Indoor,Outdoor / 802.11b / 802.11g
09-20-2017 11:17 PM
Thanks! What version is the 1552 AP running, k9w7 or k8w8? You may need to convert the software to lightweight (k9w8).
sh version
show boot
Ric
09-20-2017 11:25 PM
ap#show version
Cisco IOS Software, C1550 Software (C1520-K9W7-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 05:12 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
ap uptime is 23 minutes
System returned to ROM by reload
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Last reset from reload
2 802.11 Radios
Configuration register is 0xF
ap#
BOOT path-list:
Config file: flash:/config.txt
Private Config file: flash:/private-config
Enable IOS Break: no
HELPER path-list:
NVRAM/Config file
buffer size: 32768
Mode Button: on
Radio Core TFTP:
ap#
thanks for help
09-20-2017 11:30 PM
[Confirm]
Ric
09-20-2017 11:32 PM
ap#show flash:
Directory of flash:/
2 -rwx 6923 Mar 1 1993 00:22:13 +00:00 event.log
3 -rwx 149 Mar 1 1993 00:00:34 +00:00 env_vars
4 -rwx 1912 Mar 1 1993 00:22:12 +00:00 config.txt
5 drwx 1344 Jan 1 1970 00:09:08 +00:00 c1520-k9w7-mx.152-2.JB
205 -rwx 5 Mar 1 1993 00:22:12 +00:00 private-config
206 -rwx 1048 Mar 1 1993 00:22:12 +00:00 private-multiple-fs
31610880 bytes total (20082688 bytes free)
ap#
09-20-2017 11:33 PM
No lightweight image available so you will need to download from Cisco or see if your company has an image available.
Ric
09-20-2017 11:31 PM
do I need to do this:
conf t
boot system flash:/c1520-k9w7-mx.152-2.JB/c1520-k9w7-xx.152-2.JB
to boot the flash...Right!
09-20-2017 11:32 PM
Unfortunately not you need an image that has k9w8 in it which means it is lightweight and will use your WLC.
09-20-2017 11:35 PM
archive download command not showing!
I have copy tftp...Is it OK?
09-20-2017 11:37 PM
I have this image /c1550-k9w8-mx.153-3.JA Is it OK?
09-21-2017 01:53 AM
Hi Ric,
I put old image in AP c1520-k9w7-mx.152-2.JB in boot system but after that I couldn't access by telnet and I am in console now but AP not taking the IP address...How can I solve this problem?
Thank you for your help
Mohammad
09-21-2017 02:29 AM
Hi Mohammad,
That is also an Autonomous image meaning the AP won't use the WLC. You can probably enable telnet access with:
So the AP is no longer picking up an IP via DHCP? You need to use the image you last posted with k9w8 in it as that is a Lightweight image.
Ric
