CISCO AP 1602i: some PCs can't view SSID, mobile can connect
lqnghia80
I have a CISCO AP 1
help me fix this problem, pls
tks
7 Replies 7
Sandeep Choudhary
Can you paste the complete conifg of AP.
Dont forget to rate helpful posts
hi Sandeep
this is my AP config
Current configuration : 1901 bytes
! Last configuration change at 00:42:12 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname Tang_5.1
logging rate-limit console 9
enable secret 5 $1$sndk$SgK1Os.g0.yFs08KDvqDo.
no aaa new-model
no ip routing
no ip cef
dot11 syslog
dot11 ssid Tang_5.1
   authentication open
   guest-mode
username Cisco password 7 02250D480809
username admin privilege 15 password 7 1218011A1B055D5679
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 0E63803F2135 transmit-key
encryption mode wep mandatory
ssid Tang_5.1
antenna gain 0
stbc
beamform ofdm
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.10.245 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community defaultCommunity RW
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Can you test without any key(Without wep) mean just leave ssid open for all and test it again.
thank Sandeep
I'll try
I would recommend to use WPA or WPA2 for a SSID. Its more secure.
thank San
this problem has resolved
thank all again!
If its resolved then please mark this question as answered, it may help others.
