cisco AP 1852 I model can't upload firmware
aaaa111
This ap was working but 1weeks ago ap was down and didn't connect with WLC
and I see filesystem all diectory clear ex)/dev/ubivol/storage
please help to work normal
#show flash
Directory of /storage/
total 40
-rw-r--r-- 1 root root 3 Jan 1 1970 BOOT_COUNT
-rw-r--r-- 1 root root 3 Jan 1 1970 BOOT_COUNT.reserve
-rw-r--r-- 1 root root 28 Jul 8 15:24 RELOADED_AT_UTC
drwxr-xr-x 3 root root 224 Feb 8 2016 application
-rw-r--r-- 1 root root 482 Jul 8 15:25 base_capwap_cfg_info
-rw-r--r-- 1 root root 18 Feb 8 2016 config
-rw-r--r-- 1 root root 0 Jan 1 1970 config.local
-rw-r--r-- 1 root root 17 Jul 8 15:25 config.mobexp
drwxr-xr-x 2 root root 160 Jul 8 2024 cores
drwxr-xr-x 2 root root 320 Feb 8 2016 dropbear
drwxr-xr-x 2 root root 160 Jan 1 1970 lists
-rw-r--r-- 1 root root 63 Jan 1 1970 part1_info.ver
-rw-r--r-- 1 root root 63 Jan 1 1970 part2_info.ver
-rw-r--r-- 1 root root 4096 Jul 8 15:24 random_seed
-rw-r--r-- 1 root root 3 Feb 7 2016 rxtx_mode
drwxr-xr-x 3 support root 224 Jan 1 1970 support
drwxr-xr-x 2 root root 1760 Jul 8 15:26 syslogs
Filesystem Size Used Available Use% Mounted on
flash 57.6M 188.0K 54.4M 0% /storage
show filesystems
/dev/ubivol/storage 57.6M 188.0K 54.4M 0% /storage
8 Replies 8
marce1000
 - Post the complete boot process of the AP and also the logs from the controller when the AP
    tries to join ,
 M.
U-Boot 2012.07 (btldr release 21) (Aug 19 2015 - 10:57:19)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected SPANSION S34MS02G1 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:1], write_counter=20
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
GPIO 7: Pull High detected...
Power Type: 802.3at POE detected...
Image start 0x45000000 size 0x00138000
Key start 0x45138000 size 0x00000230
Sinature start 0x45138230 size 0x00000180
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part1
Booting from part1
Read 1024 bytes from volume part1 to 45000000
Read 16700627 bytes from volume part1 to 45000000
Image start 0x45000000 size 0x00feccd3
Key start 0x45feccd3 size 0x00000230
Sinature start 0x45fecf03 size 0x00000180
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] Linux version 3.4.103 (pkpanda@cheetah-build) (gcc version 4.7.1 (GCC) ) #3 SMP PREEMPT Fri Dec 11 19:19:30 PST 2015
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 console=ttyHSL1,9600n8 activepart=part1 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:10.4469] buginf tty flushing thread started, ttyport=ef5f7890
[01/01/1970 00:00:15.1354] watchdog: only one watchdog can use /dev/watchdog
[01/01/1970 00:00:15.2054] watchdog: error registering /dev/watchdog (err=-16)
[*01/01/1970 00:00:15.3753] buginf() enabled.
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
[*01/01/1970 00:00:15.3853] Made it into bootsh: Dec 11 2015 19:14:25
[*01/01/1970 00:00:15.3853] bootsh build T-71a34d52a2a5f1ee540fd6cd95cb7fe59aa535a5-g71a34d52-pkpanda
init started: BusyBox v1.20.2 (2015-12-11 18:40:16 PST)
User Access Verification
Username: [*01/01/1970 00:00:18.3344] copy part1_info.ver to CAPWAP_VERSION.
[*01/01/1970 00:00:18.3444] copy part2_info.ver to CAPWAP_BAK_VERSION.
[*01/01/1970 00:00:18.5643] nss_driver - Turbo Support 1
[*01/01/1970 00:00:19.0342] Current value of FACTORY_RESET=0
[*02/07/2016 23:59:59.0000] Last reload time: Jul 8 15:33:24 2024
[*07/08/2024 15:33:24.0000] Setting system time Mon Jul 8 15:33:24 UTC 2024
[*07/08/2024 15:33:24.0499] device wired0 entered promiscuous mode
[*07/08/2024 15:33:24.1499] device wired1 entered promiscuous mode
[*07/08/2024 15:33:24.4898] click: starting router thread pid 11[07/08/2024 15:33:24.5298] stile module dp init successfully
[07/08/2024 15:33:24.6198] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Jun 16 2015 at 18:59:03
12 (c4413800)
[*07/08/2024 15:33:24.5098] stile_lm_ft_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[*07/08/2024 15:33:24.5298] stile_lm_dp_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[*07/08/2024 15:33:24.8597] S10boot: file "/storage/rxtx_mode" found.
[*07/08/2024 15:33:24.8697] pid 1112's current affinity mask: 3
[*07/08/2024 15:33:24.8697] pid 1112's new affinity mask: 2
[*07/08/2024 15:33:24.8897] pid 1164's current affinity mask: 3
[*07/08/2024 15:33:24.8897] pid 1164's new affinity mask: 1
[*07/08/2024 15:33:24.9497]
[*07/08/2024 15:33:24.9497] boot 18 build T-71a34d52a2a5f1ee540fd6cd95cb7fe59aa535a5-g71a34d52-pkpanda board corsica mac DC:CE:C1:26:28:30
[*07/08/2024 15:33:24.9597] Module: qca_nss_gmac .text=0xbf000000 .data=0xbf00794c .bss=0xbf007dc0
[*07/08/2024 15:33:24.9597] Module: qca_nss_drv .text=0xbf012000 .data=0xbf021d68 .bss=0xbf022998
[*07/08/2024 15:33:24.9597] Module: qca_nss_capwapmgr .text=0xbf037000 .data=0xbf03ab18 .bss=0xbf03ac70
[*07/08/2024 15:33:24.9597] Module: nssmgrctl .text=0xbf040000 .data=0xbf04171c .bss=0xbf041a48
[*07/08/2024 15:33:24.9597] Module: proclikefs .text=0xbf047000 .data= .bss=0xbf047b40
[*07/08/2024 15:33:24.9597] Module: stile_lm_ft .text= .data= .bss=
[*07/08/2024 15:33:24.9597] Module: stile_lm_dp .text= .data= .bss=
[*07/08/2024 15:33:24.9597] Module: qca_nss_profile_drv .text=0xbfad0000 .data=0xbfad1324 .bss=0xbfad14a0
[*07/08/2024 15:33:25.3296] Last reload reason : capwapd triggered reboot
[*07/08/2024 15:33:26.5292] adf: module license 'Proprietary' taints kernel.
[*07/08/2024 15:33:26.5292] asf: module license 'Proprietary' taints kernel.
[*07/08/2024 15:33:26.5392] ath_hal: module license 'Proprietary' taints kernel.
[*07/08/2024 15:33:26.5392] ath_dfs: module license 'Proprietary' taints kernel.
[*07/08/2024 15:33:26.5492] ath_rate_atheros: module license 'Proprietary' taints kernel.
[*07/08/2024 15:33:26.5592] ath_dev: module license 'Proprietary' taints kernel.
[*07/08/2024 15:33:26.5892] Chip id: 0x9, chip version: 0x1000000
[*07/08/2024 15:33:26.5892] Target Version is 1000000
[*07/08/2024 15:33:26.5892] Flash Download Address c0000
[*07/08/2024 15:33:26.5892] ol_transfer_bin_file: flash data file defined
[*07/08/2024 15:33:26.5892] Cal location [0]: 00000000
[*07/08/2024 15:33:26.5892] Wifi0 Select OFFSET 1000
[*07/08/2024 15:33:26.6092] qc98xx_verify_checksum: flash checksum passed: 0xd298
[*07/08/2024 15:33:26.6092] ol_transfer_bin_file 2975: Download Flash data len 12064
[*07/08/2024 15:33:26.6292]
[*07/08/2024 15:33:26.6292] Board data initialized
[*07/08/2024 15:33:31.2977] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*07/08/2024 15:33:31.2977] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*07/08/2024 15:33:31.2977] ol_transfer_bin_file: Board data file: AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin ARXXXX v=0x1
[*07/08/2024 15:33:31.2977] ol_transfer_bin_file:Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*07/08/2024 15:33:31.4877] pid 1389's current affinity mask: 3
[*07/08/2024 15:33:31.4877] pid 1389's new affinity mask: 1
[*07/08/2024 15:33:35.9863] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/08/2024 15:33:37.1059] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/08/2024 15:33:37.1059] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/08/2024 15:33:37.1059] host/RAM_fw Build Ver Mismatch: H:0x3D, F:0x40 !
[*07/08/2024 15:33:37.1059] num_rf_chain:0x00000004 ht_cap_info:0x0000085b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffea
[*07/08/2024 15:33:37.1059] Peer Caching Enabled ; num_peers = 529, num_active_peers = 67 num_tids = 134, num_vdevs = 17
[*07/08/2024 15:33:37.1659] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/08/2024 15:33:37.1659] ACS not enabled
[*07/08/2024 15:33:37.1659] ol_ath_thermal_mitigation_attach: --
[*07/08/2024 15:33:37.1859] Chip id: 0x9, chip version: 0x1000000
[*07/08/2024 15:33:37.1859] Target Version is 1000000
[*07/08/2024 15:33:37.1859] Flash Download Address c0000
[*07/08/2024 15:33:37.1859] ol_transfer_bin_file: flash data file defined
[*07/08/2024 15:33:37.1859] Cal location [1]: 00004000
[*07/08/2024 15:33:37.1859] Wifi1 Select OFFSET 5000
[*07/08/2024 15:33:37.2059] qc98xx_verify_checksum: flash checksum passed: 0x f0b
[*07/08/2024 15:33:37.2059] ol_transfer_bin_file 2975: Download Flash data len 12064
[*07/08/2024 15:33:37.2259]
[*07/08/2024 15:33:37.2259] Board data initialized
[*07/08/2024 15:33:38.1056] FWLOG: [32778] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:38.1056] FWLOG: [32778] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:38.1056] FWLOG: [32778] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:38.1056] FWLOG: [32778] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:41.8744] ol_ath_download_firmware :First OTP download and Execute is good address:0x9c00 return param 4660
[*07/08/2024 15:33:41.8744] ol_ath_download_firmware:##Board Id 7 , CHIP Id 1
[*07/08/2024 15:33:41.8744] ol_transfer_bin_file: Board data file: AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin ARXXXX v=0x1
[*07/08/2024 15:33:41.8744] ol_transfer_bin_file:Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin
[*07/08/2024 15:33:46.5629] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/08/2024 15:33:47.6526] Loading sha2...
[*07/08/2024 15:33:47.6526] Dumpping sha1...
[*07/08/2024 15:33:47.6826] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/08/2024 15:33:47.6826] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/08/2024 15:33:47.6826] host/RAM_fw Build Ver Mismatch: H:0x3D, F:0x40 !
[*07/08/2024 15:33:47.6826] num_rf_chain:0x00000004 ht_cap_info:0x0000085b vht_cap_info:0x339b79b2 vht_supp_mcs:0x0000ffea
[*07/08/2024 15:33:47.6826] Peer Caching Enabled ; num_peers = 529, num_active_peers = 67 num_tids = 134, num_vdevs = 17
[*07/08/2024 15:33:47.7326] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/08/2024 15:33:47.7426] acfg_attach: using existing sock ebde8200
[*07/08/2024 15:33:47.7426] ACS not enabled
[*07/08/2024 15:33:47.7426] ol_ath_thermal_mitigation_attach: --
[*07/08/2024 15:33:47.7526] ath_pktlog: module license 'unspecified' taints kernel.
[*07/08/2024 15:33:47.7726]
[*07/08/2024 15:33:47.7726] !!!!! {/usr/bin/capwap_brain} failed writing /click/drop_vrrp_advertisements/switch len 2 data: "-1"
[*07/08/2024 15:33:47.7726] !!!!! {/usr/bin/capwap_brain} failed writing /click/vrrp_elector/flex_stop len 1 data: "1"
[*07/08/2024 15:33:48.5423] Loading MIC cert and key
[*07/08/2024 15:33:48.5423] Dumpping sha2...
[*07/08/2024 15:33:48.6823] FWLOG: [43568] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:48.6823] FWLOG: [43568] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:48.6823] FWLOG: [43568] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:48.6823] FWLOG: [43568] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x518, 0x518, 0x0 )
[*07/08/2024 15:33:49.3321] click-config/io-real.click:69: While configuring 'todev_nsscapwap0 :: ToDevice':
[*07/08/2024 15:33:49.3321] warning: device 'nsscapwap0' is down
[*07/08/2024 15:33:49.3621] click-config/io-real.click:69: While configuring 'fromdev_nsscapwap0 :: FromDevice':
[*07/08/2024 15:33:49.3621] warning: device 'nsscapwap0' is down
[*07/08/2024 15:33:49.6220] Loading MIC cert and key
[*07/08/2024 15:33:49.6620] Generating key, this may take a while...
[*07/08/2024 15:33:49.9719] In write handler 'run' for 'set_enabled :: Script':
[*07/08/2024 15:33:49.9719] While calling 'client_ip_table.enable_vap_to_inet 16 0':
[*07/08/2024 15:33:49.9719] VAP: value 16 out of range, bound 15
[*07/08/2024 15:33:50.0319] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*07/08/2024 15:33:51.4614] wired0: 1000Mbps FullDuplex
[*07/08/2024 15:33:51.6713] ethernet_port wired0, ip 192.168.20.13, netmask 255.255.255.0, gw 192.168.20.1, mtu 1500, bcast 192.168.20.255, dns1 0.0.0.0, is_static true, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*07/08/2024 15:33:52.1512] Public key portion is:
[*07/08/2024 15:33:52.1512] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCmBfsLgCM0xRnkhw7EM54sIwH92/NRX6s4yta7rVI+OV6DrxCp6Dc9RX15erYe6yjL0Me8PjousyFObVA+N5WaRIlw1cU72IQ62LaY+GS8BV7FvvbJJkjLtk+HGsB1pF/UyfQHCcoJerKzCkTU1hL+V1U3Z3sMm1F+hgIqoyCQI2MC4I6Z9/e7yka35V67eSNFp7Z8m4F5QRdlQwm8aSplbHEQKwEMpQ9/XWTPQYf5h6BmHidPRvGsqEuCkhVTp01UFnDTzy7ZSf19bJTlKMcsjP+qXrwoxH1t6vW9ovlL+OeT3ATcgGfzlokE+pvpYKaiMup6rKRDT8lOaPxeEQcn root@mDCCEC1262830
[*07/08/2024 15:33:52.1512] Fingerprint: md5 5e:9e:5f:94:87:e1:3c:a2:52:47:9c:fe:7e:27:85:61
[*07/08/2024 15:33:52.2012] pid 2609's current affinity mask: 3
[*07/08/2024 15:33:52.2012] pid 2609's new affinity mask: 1
[*07/08/2024 15:33:52.2012] killall -q wcpd 2>/dev/null
[*07/08/2024 15:33:52.2212] show_carrier_cookies
[*07/08/2024 15:33:52.3111] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/1/g' -e 's/__DOMAIN_5G__/51/g' -e 's/__PRODUCT_ID__/AIR-AP1852I-H-K9/g' -e 's/__AP_TYPE__/48/g' -e 's/__WIRELESS_MAC__/DC:CE:C1:27:0A:C0/g' | DMALLOC_OPTIONS=debug=0x4e48503,inter=1000,log=/tmp/wcp.dmalloc.log,limit=35000000 wcpd &
[*07/08/2024 15:33:52.5911] Password for 'Cisco' changed
[*07/08/2024 15:33:52.6410] lwapp_crypto_init: MIC Present and Parsed Successfully
[*07/08/2024 15:33:52.6410] WTP IP Address = 192.168.20.13
[*07/08/2024 15:33:52.6810] control socket configure: Connection refused
[*07/08/2024 15:33:52.6810] Failed to start timer, NULL timer handle
[*07/08/2024 15:33:52.6810] CAPWAP debug flag read timer start failed
[*07/08/2024 15:33:52.7110] DOT11_TXP[0]:Domain configured: 1 class:E
[*07/08/2024 15:33:52.8210] DOT11_TXP[1]:Domain configured: 51 class:H
[*07/08/2024 15:33:53.3108] click-config/wcp.usermodule.template:10: While initializing 'fromdev_wcp_radio1 :: FromDevice':
[*07/08/2024 15:33:53.3108] warning: wcp_radio1: no IPv4 address assigned
[*07/08/2024 15:33:53.4008] click-config/wcp.usermodule.template:16: While initializing 'fromdev_wcp_cwx :: FromDevice':
[*07/08/2024 15:33:53.4008] warning: wcp_cwx: no IPv4 address assigned
[*07/08/2024 15:33:53.5108] click-config/wcp.usermodule.template:13: While initializing 'fromdev_wcp_wired :: FromDevice':
[*07/08/2024 15:33:53.5108] warning: wcp_wired: no IPv4 address assigned
[*07/08/2024 15:33:53.6407] click-config/wcp.usermodule.template:7: While initializing 'fromdev_wcp_radio0 :: FromDevice':
[*07/08/2024 15:33:53.6407] warning: wcp_radio0: no IPv4 address assigned
[*07/08/2024 15:33:53.6407] DOT11_DRV[1]: vendor_init_radio Init Radio1
[*07/08/2024 15:33:53.6407] ol_ath_set_channel set channel freq 5180
[*07/08/2024 15:33:53.6407] ol_ath_set_channel: Different channel, need to restart all VAPs
[*07/08/2024 15:33:53.6507] DOT11_DRV[1]: vendor_stop_radio Stop Radio1
[*07/08/2024 15:33:53.6507] DOT11_DRV[1]: vendor_set_phy_mode set mode_str 11A succeeded
[*07/08/2024 15:33:53.6507] DOT11_DRV[1]: set_channel Channel set to 36
[*07/08/2024 15:33:53.6507] DOT11_DRV[0]: vendor_init_radio Init Radio0
[*07/08/2024 15:33:53.6607] ol_ath_set_channel set channel freq 2412
[*07/08/2024 15:33:53.6607] ol_ath_set_channel: Different channel, need to restart all VAPs
[*07/08/2024 15:33:53.6607] DOT11_DRV[0]: vendor_stop_radio Stop Radio0
[*07/08/2024 15:33:53.6607] DOT11_DRV[0]: vendor_set_phy_mode set mode_str 11G succeeded
[*07/08/2024 15:33:53.6607] DOT11_DRV[0]: set_channel Channel set to 6
[*07/08/2024 15:33:53.6907] MSGPROC: Waiting for wcp to start - 1
[*07/08/2024 15:33:53.6907] Starting Discovery.
[*07/08/2024 15:33:53.6907] CAPWAP State: Discovery.
[*07/08/2024 15:33:53.6907] Did not get log server settings from DHCP.
[*07/08/2024 15:33:53.6907] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:33:53.7107] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:33:53.7107] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:33:53.7207] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:33:53.7207] CAPWAP State: Init.
[*07/08/2024 15:33:53.7207] CAPWAP State: Discovery.
[*07/08/2024 15:33:54.7704] device capwap0 entered promiscuous mode
[*07/08/2024 15:33:54.8204] device capwap1 entered promiscuous mode
[*07/08/2024 15:34:03.1378] Could not discover any MWAR.
[*07/08/2024 15:34:03.1378] Starting Discovery.
[*07/08/2024 15:34:03.1378] CAPWAP State: Discovery.
[*07/08/2024 15:34:03.1378] Did not get log server settings from DHCP.
[*07/08/2024 15:34:03.1378] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:34:03.1578] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:34:03.1578] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:34:03.1678] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:34:12.6348] Could not discover any MWAR.
[*07/08/2024 15:34:12.6448] Starting Discovery.
[*07/08/2024 15:34:12.6448] CAPWAP State: Discovery.
[*07/08/2024 15:34:12.6448] Did not get log server settings from DHCP.
[*07/08/2024 15:34:12.6448] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:34:12.6648] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:34:12.6648] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:34:12.6748] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:34:22.1418] Could not discover any MWAR.
[*07/08/2024 15:34:22.1418] Starting Discovery.
[*07/08/2024 15:34:22.1418] CAPWAP State: Discovery.
[*07/08/2024 15:34:22.1418] Did not get log server settings from DHCP.
[*07/08/2024 15:34:22.1418] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:34:22.1618] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:34:22.1618] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:34:22.1718] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:34:31.6489] Could not discover any MWAR.
[*07/08/2024 15:34:31.6489] Starting Discovery.
[*07/08/2024 15:34:31.6489] CAPWAP State: Discovery.
[*07/08/2024 15:34:31.6489] Did not get log server settings from DHCP.
[*07/08/2024 15:34:31.6489] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:34:31.6589] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:34:31.6589] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:34:31.6689] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:34:41.1559] Could not discover any MWAR.
[*07/08/2024 15:34:41.1559] Starting Discovery.
[*07/08/2024 15:34:41.1559] CAPWAP State: Discovery.
[*07/08/2024 15:34:41.1559] Did not get log server settings from DHCP.
[*07/08/2024 15:34:41.1559] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:34:41.1659] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:34:41.1659] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:34:41.1859] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:34:50.6529] Could not discover any MWAR.
[*07/08/2024 15:34:50.6529] Starting Discovery.
[*07/08/2024 15:34:50.6529] CAPWAP State: Discovery.
[*07/08/2024 15:34:50.6529] Did not get log server settings from DHCP.
[*07/08/2024 15:34:50.6529] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:34:50.6729] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:34:50.6729] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:34:50.6829] Discovery Request sent to 255.255.255.255 with discovery type set to 0
Username: [*07/08/2024 15:35:00.1599] Could not discover any MWAR.
[*07/08/2024 15:35:00.1599] Starting Discovery.
[*07/08/2024 15:35:00.1599] CAPWAP State: Discovery.
[*07/08/2024 15:35:00.1599] Did not get log server settings from DHCP.
[*07/08/2024 15:35:00.1599] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:35:00.1699] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:35:00.1699] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:35:00.1899] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:35:09.6670] Could not discover any MWAR.
[*07/08/2024 15:35:09.6670] Starting Discovery.
[*07/08/2024 15:35:09.6670] CAPWAP State: Discovery.
[*07/08/2024 15:35:09.6670] Did not get log server settings from DHCP.
[*07/08/2024 15:35:09.6670] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:35:09.6870] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:35:09.6870] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:35:09.6970] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:35:19.1640] Could not discover any MWAR.
[*07/08/2024 15:35:19.1640] Starting Discovery.
[*07/08/2024 15:35:19.1640] CAPWAP State: Discovery.
[*07/08/2024 15:35:19.1640] Did not get log server settings from DHCP.
[*07/08/2024 15:35:19.1740] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:35:19.1840] Discovery Request sent to 192.168.20.10 with discovery type set to 1
[*07/08/2024 15:35:19.1840] SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1431, Controller Master: IP Address 192.168.20.10
[*07/08/2024 15:35:19.2040] Discovery Request sent to 255.255.255.255 with discovery type set to 0
[*07/08/2024 15:35:23.2227]
[*07/08/2024 15:35:23.2227] phy_value=0: org="0x1000" phy_reg="0x1800"
[*07/08/2024 15:35:28.6710] Could not discover any MWAR.
[*07/08/2024 15:35:28.6710] Starting Discovery.
[*07/08/2024 15:35:28.6710] CAPWAP State: Discovery.
[*07/08/2024 15:35:28.6710] Did not get log server settings from DHCP.
[*07/08/2024 15:35:28.6710] Could Not resolve CISCO-CAPWAP-CONTROLLER
[*07/08/2024 15:35:28.6810] Discovery Request sent to 192.168.20.10 with discovery type set to 1
down the sector is boot process
aaaa111
DRAM: 1 GiB
MFG data loaded
Total valid parts=4
Net:
Signature returns 0
Booting from part1
Signature returns 0
Starting image ...
Welcome to Cisco.
available at:
Cisco Systems, Inc.
export@cisco.com.
12 (c4413800)
The Boot process
  - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu65028
    Try solution from paragraph : Workaround:
   M.
Thank you I will try
Rich R
What model of WLC are you using?
What version of software is the WLC running?
What version of software is the AP running (show ver)?
What is the IP address of the WLC?
The AP is not getting any response from the WLC when it sends CAPWAP discovery which means one of:
- WLC has stopped responding due to software or hardware problem.  If software then upgrade to the latest TAC recommended version as per the TAC recommended link below.  If hardware then repair/replace the hardware.
- Loss of network connectivity to WLC.  Check the connectivity to the WLC and make sure the AP can ping the WLC.
- Faulty AP ethernet port or switch port.  Make sure you can ping the local default gateway from the AP to confirm AP and switch port working correctly.  If not check switch port config or try a different port.
aaaa111
I solve that problem.
was ap 1852 got 8.2.100 firmware version
so I was upgraded version 8.3.140 than up grade to 8.10.x and now it okay.
Thank you for your concern!!
