Cisco AP 2602 Auto Mode Configuration save
interface31
i have some Cisco i2602 in Auto Mode on a Cisco Catalyst 2960-c
Works with Fast Ethernet
Now i want to Change to Gigabit Switch.
Now i have the problem some AP no work, it looks like that the start but after some minutes
there are off.
There are 4 pair cable.
I check the cable crimping and looks ok.
Can i save the config from a working AP and load them to the other?
cu
Mark Elsen
 - You may for instance first want to 1) Check the logs on the  Catalyst 2960-c when the AP goes off 2) Check the interface status for the particular off-ap  3) Check port counters.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
No with the 2960-c it works all everything fine.
I want to upgrade to a faster Switch,
I try a Huawei Switch i got this faulty message when i test the ports.
Don´t know whats the problem, is this cable so bad for a Gigabit Switch?
cu
