01-15-2013 03:28 AM - edited 07-03-2021 11:20 PM
Dear Folks,
Is it possible to have Cisco 3500 AP's in an existing 4400 controller with clean air functionality. I read somewhere in document that 3600 doesnt support 7.2 version in 4400 etc
I couldnt find in cisco site, whether Cisco 3500 AP can use clean air functionality when connected to 4400 controller .
SID
Solved! Go to Solution.
01-15-2013 05:48 AM
Little confused .. You mentioned 3500 in your subject but in your body of the post you state 3600 ..
3500 is supported on a 4400 with 7.0 code
3600 is not support on the 4400 because it requires 7.2 code. The 4400 doesn't support 7.2 code and stops at 7.0 code ..
01-15-2013 04:11 AM
Hi SID,
Clean Air is support on the 4400 WLCs, 7.2 isn;t though.
Chris
Edit: It's the 3600 series APs that aren't supported.
01-15-2013 05:44 AM
Take a look at this document. It goes of the compatibility of each device.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
01-15-2013 05:48 AM
01-15-2013 05:58 AM
Hi George,
What i was looking for is 3500 . But i could only get document regarding incompatibility related with 3600 and 4400 series controller. So i wanna make sure , that 3500 supports 4400 controller in terms of clean air configuration .
Thanks .
01-15-2013 06:04 AM
Yes 3500 was the first clean air ap introduced. It does work with 4400 in clean air mode.
01-15-2013 06:20 AM
The compatibility matrix shows you that the 3500's are supported if running 7.0.x which is the last supported code on the 4400, which is also in that matrix.
