Cisco AP 3702i and 3502i configurations
ayo.okus
I need help configuring my AP for home use... I figured the AP has a lightweight software on it and I have not been able to do anything with it. Please help. I need to use this for home use...
Scott Fella
Well, if it has a lightweight image, you will need to have the ability to download the autonomous image for that ap. That requires a support contract. There is no other was to covert that ap.
-Scott
Thanks a lot...  I was able to download the K9w7 and loaded through TFTP but the AP keeps loading the k9w8
When you say you 'loaded through TFTP' do you mean you simply copied the .tar file onto the flash or you actually installed it?
To be clear - in order to install the software on an AP you need to use the command:
archive download-sw tftp://A.B.C.D/<k9w7-image>.tar
That downloads the tar file, extracts the contents to flash and sets the boot variables to use the new image on next reload.
Is that what you did?
What is the output of show boot?
