Cisco AP C9115AXE-E Cupertino 17.09.04 firmware change to Lightweight
XYtras
By a mistake I've downloaded and installed newest Cupertino 17.09.04 firmware on Cisco AP C9115AXE-E
Now there is no capwap commands to add this AP to my WLC.
I need to "downgrade" it to Lightweight firmware. I have correct firmware (ap1g7-k9w8-tar.153-3.JPQ.tar) but can't install it by AP's website. I can upload it by TFTP but dont know the commands and how to install this TAR firmware on my AP. There is no (not working on my AP) "archive download-sw" -  command.
Please help.
2 Accepted Solutions
Rich R
Ok @XYtras a few points...
The ap-type command must be entered from the AP CLI, not the EWC WLC CLI.
To access the AP CLI from EWC: “wireless ewc-ap ap shell username <username>
The username and password depend on what you configured when you setup the EWC, but might also still be default Cisco/Cisco.
This is documented at https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html#toc-hId--865113225
Now back to your original problem - getting rid of EWC: "ap-type capwap" will make it boot back to standard CAPWAP mode but it has a nasty habit of re-activating EWC if it can't find a WLC for any reason when it boots up so I always recommend a complete re-flash of the AP to remove the IOS-XE software completely.  To do that use the process and software at:
 https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html
That will revert the AP to 8.10.130.0 CAPWAP software and then you can upgrade to the right version from there.
XYtras
Thank you all for all your help. To summarize in few words (commands):
wireless ewc-ap ap shell username Cisco
pass: Cisco
en
ap-type capwap
7 Replies 7
marce1000
  - Try this on the AP : # ap-type capwap
M.
Hi, thanks for reply. The problem is that I've downloaded and installed Embedded Wireless Controller 17.9.4 (C9100 EWC AP bundle image C9800-AP-universalk9.17.09.04.zip) to the Cisco AP C9115AXE-E. Now I can't add this AP to my WLC. There is no capwap commands anymore.
To solve it I must download and install correct - Lightweight AP Software. I've already downloaded WIRELESS LAN LWAPP ap1g7-k9w8-tar.153-3.JPQ.tar
I have TFTP soft running with correct TAR image, but I've no idea what commands to use to upload and install Lightweight AP Soft and what commands use to upload&install it sucessfuly on my AP.
I will add that I don't have AP on site, it gets to it remotely via other PC and the console cable.
               - Please execute my initial reply ,
 M.
I've tried it immediately but it's not working:
Oct 24 08:57:02.646: %SYS-5-CONFIG_I: Configured from console by console
AP-09#ap-type capwap
% Invalid input detected at '^' marker.
AP-09#
AP-09#ap?
ap app-hosting
AP-09#
AP-09>sh ver
Cisco IOS XE Software, Version 17.09.04
Cisco IOS Software [Cupertino], C9800-AP Software (C9800-AP-K9_IOSXE-UNIVERSALK9-M), Version 17.9.4, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2023 by Cisco Systems, Inc.
Compiled Wed 26-Jul-23 09:57 by mcpre
System restarted at 15:22:32 UTC Mon Oct 23 2023
System image file is "/tmp/sw/rp/0/0/rp_wlc/mount/usr/binos/bin/linux_iosd-image"
Last reload reason: Reload Command
AIR License Level: AIR Network Essentials
cisco C9115AXI-E (VXE) processor (revision VXE) with 321661K bytes of memory.
Processor board ID FCW2718Y3WU
2048K bytes of non-volatile configuration memory.
1971460K bytes of physical memory.
100000K bytes of AP Images at ap_images:.
513300K bytes of Backup Controller Image at backup_image:.
7774207K bytes of virtual hard disk at bootflash:.
25000K bytes of Temp trace export at tmp_trace_export:.
Installation mode is BUNDLE
 - FYI : https://community.cisco.com/t5/wireless/how-to-convert-from-ewc-to-capwap-mode/m-p/4664457#M244916
 M.
Rich R
XYtras
pass: Cisco
en
ap-type capwap
