Cisco AP compatibility with other vendor APs
larsent
We are about to migrate a site running Symbol AP4131 managed by a Symbol WS5000 to an all Cisco 1242 AP.
I am trying to verify the APs will work together as we do the migration. Currently the Symbols are running a static WEP key. If I configure the Cisco to use the same WEP key will the end user have any issues roaming from the Cisco AP to the Symbol AP?
Thanks.
Mr. Bash
To be honest you very well may run into issues with multi vendor AP's. I don't know that there is any way to know for sure ahead of time whether or not you'll run into issues.
Your best bet may be to setup a lab environment and testing roaming to see if you have any drop offs etc.
