CISCO AP INTERFERENCE ISSUE
EdwinThoo
Frequent Visitor
Frequent Visitor
Hi Guys, I have not much experience and knowledge on wireless and current facing interference issue...
The photo shown channel utilization 82% and interference 75% high , even i change the channel for some of the AP but its still the same.
is there anyway i can reduce the interference and channel utilization?
I can't see the photo but if this Channle Utilization is for 2.4 GHz then I'd say it is normal depends on the circumstances.
 If you are using WLC let it do the job, just apply best practices by disabling low data rates, enable EDRRM, CleanAir and avoid using 2.4GHz.
 If this is an autonomous AP then you have less resource.
 Please, provide more information.
-If I helped you somehow, please, rate it as useful.-
Leo Laohoo
Channel utilization and Interference is always high in 2.4 Ghz that's because every-man-and-his-pony has 2.4 Ghz turned on to full blast.  Gets worst when doing readings in an office block/space environment.
