Cisco AP to AP (point to point) connection
Pavel Pokorny
Dear all,
I'm new to this and I have question.
Imagine location where are two switches, and I can't use wire to interconnet them, but I have to use wireless.
Can you suggest solution?
Topology:
clients <-> switch <-> AP   air   AP <-> switch <-> clients
I have found following:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a00805b9b87.shtml
But there are wireless clients on the other side. I need wired (as you can see), or is there any difference?
Does anyone has simple config example?
Thank you very much
Pavel
tfraij
Hello Pavel,
you can use root , non root bridge setup.
and on any of them you can add wireless clients support
by command , station role root bridge wireless-client
here is some configuration commands i used previously on root-nonroot setup
ROOT
AP(config)#dot11 ssid talal
AP(config-ssid)#authentication open
AP(config-ssid)#guest-mode
AP(config-ssid)#infrastructure-ssid
AP(config-ssid)#exit
AP(config)#int dot11radio 0
AP(config-if)#encryption mode wep mandatory
AP(config-if)#encryption key 1 size 40bit 123456789a
AP(config-if)#ssid talal
AP(config-if)#no shutdown
AP(config-if)#station-role root Bridge
Ap(config)#int bvi 1
AP(config-if)ip address 192.168.1.20
NON root
AP(config-if)#station-role non-root bridge
AP(config-if)#ip address 192.168.1.10
Kind regards
Talal
please rate answers that you find useful , and mark as answered - when it is :-) - so others can find it easily
Hello Pavel,
Talal is right, u can make a root AP1 and other AP2 will non-root and u can configure your AP through command or GUI mode.
Thanks for quick answer.
I suppose, there is no difference, if clients (on both sides) are wired or wireless (just not adding wireless clients support).
Am I right?
Thnx
Pavel
No difference.. what Talal and Chandan mentioned above is like if you connected a wired between the two switches.
-Scott
