Cisco AP1242 <-> Intel PRO/Wireless NIC no connect
wthoma
i try to connect a Notebook with an integrated Intel PRO/Wireless NIC to an AP1240. Both are comletely blind to each other. The NIC can see another AP (FritzBOX WLAN) without problems. When inserting a CISCO PCM352 NIC its all ok, too. But its wishful to use the integrated one. The 1240 is only configured with IP Address and a SSID, without security and things, for troubleshooting issues. Does anyone have an idea ?
Oh.. i updated the AP and the NIC with the most actual firmware and drivers.
Thanks in advance
wolfgang
jim_pliss
You might want to remove the Intel controller software and let windows manage the network connections. Install only the network card driver. I am assuming you are using windows. Also check out ms KB885453 might help you there too.
d-berlinski
Those NIC cards are junk. We have them in a bunch of our laptops and we experience connection issues contantly. There are many articles out there on them. Avoid them if you can.
