Cisco AP1560 as WGB Issues
Hi Team,
I'm facing an issue with a Cisco AP1560 as a WGB.
Behind the AP i've got a MicroSwitch CMICR-4PC that will have a PC connect to it.
The AP is running AP Running Image : 8.10.151.0
The issue is that for some reason i get message errors on the logs on the AP side.
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:29.9976] Received disassociate (uplink)[A0:23:9F:85:CC:80], (bssid)[34:ED:1B:DC:29:20] (252) unknown
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0057] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' went down
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0137] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' came up
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0280] IPv6: ADDRCONF(NETDEV_UP): srcr2: link is not ready
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0499] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' went down
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0578] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' came up
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0744] IPv6: ADDRCONF(NETDEV_UP): srcr2: link is not ready
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0778] Received deauthenticate (uplink)[A0:23:9F:85:CC:80], (bssid)[34:ED:1B:DC:29:20] (252) unknown
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0853] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' went down
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.0934] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' came up
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.1046] IPv6: ADDRCONF(NETDEV_UP): srcr2: link is not ready
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.1263] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' went down
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.1342] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' came up
Apr 14 18:07:30 kernel: [*04/14/2022 18:07:30.1453] IPv6: ADDRCONF(NETDEV_UP): srcr2: link is not ready
Apr 14 18:07:31 kernel: [*04/14/2022 18:07:31.0765] DOT11_UPLINK_CONFIG: tx_pow_lvl: 1
Apr 14 18:07:31 kernel: [*04/14/2022 18:07:31.1697] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' went down
Apr 14 18:07:31 kernel: [*04/14/2022 18:07:31.1779] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' came up
Apr 14 18:07:31 kernel: [*04/14/2022 18:07:31.1889] IPv6: ADDRCONF(NETDEV_UP): srcr2: link is not ready
Apr 14 18:07:31 kernel: [*04/14/2022 18:07:31.1926] DOT11-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP Escritorio 34:ED:1B:DC:29:20 [WPA2 PSK]
Apr 14 18:07:35 kernel: [*04/14/2022 18:07:35.2183] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' went down
Apr 14 18:07:35 kernel: [*04/14/2022 18:07:35.2264] chatter: tohost_apphostintf1 :: ToHost: device 'apphostintf1' came up
When this error appear i got some timeouts.
I'm not able to see why does this error message appears.
Does anyone get this behavior before?
0 Replies 0
