Cisco AP1602i interface gigabit doesn't start
kap1
Couple of days ago I wrote about not being able to configure my ap's 1602i to work as root and repeater. Today I have different problem. When I tried to connect my pc to repeater device using ethernet cable I didn't get access to network. I tried to set up static ip addres on g0 interface and no shutdown but interface is only in reset mode and it stays like that. I am not using poe switch to power the devices I have external power injector. Both ap's can ping each other and default gateway of my router. after configuring bvi 1 interface on repeater ap showed messages:
*Mar 1 00:13:44.991: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:13:49.683: dot11_mgmt: bad cookie returned from driver for mac 2c3e.cf1c.3f90(expected 0x0, got 0x4B7231C) - force driver to delete client
*Mar 1 00:13:50.063: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:13:51.063: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:13:51.067: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP root 2c3e.cf1c.3f90 [None WPAv2 PSK]
*Mar 1 00:13:52.059: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to down
*Mar 1 00:13:52.071: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:13:53.071: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
In attachments there are running config and show ip interface brief for both devices did anyone have similar problem to mine ? I am assuming that if my pc can't connect to ap then the switch wouldn't, but in order to make my desired wireless bridge configuration I have to be able to directly access ap using ethernet cable please help
  - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCup45780
             https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsv82129
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
9 Replies 9
Mark Elsen
    - FYI : https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=bad%20cookie%20returned%20from%20driver%20for%20mac&bt=custV&sb=anfr
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Link doesn't work
- Wait a bit ,
M.
       Beauty and terror
      Just keep going
       No feeling is final
It shows: No Matching Bugs Found. Please change your search criteria.
Can you please send screenschots if you have solution to my problem?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I don't see solution to my problem in these links. Version on my ap's ap1g2-k9w7-tar.152-4.JA1.tar
       >... When I tried to connect my pc to repeater device using ethernet cable I didn't get access to network.
    - I would advice to always use a switch in between and not connect pc direct to the repeater ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
Both of those bugs are Terminated (not fixed).
Start by updating the APs to last available release: ap1g2-k9w7-tar.153-3.JF15.tar to ensure you eliminate any known, fixed bugs.
But ethernet port not coming up seems fairly fundamental.  Have you tried connecting it to the switch? Are you sure it's a working cable?  Let's see "show run int go"?
kap1
https://networkguy.de/?p=799 that config was the solution to my problem thank you for your help
