Cisco AV-Pair or AAA Attribute for Multicast VLAN on 9800
Sean Aindow
I was wondering if anyone knows if its possible to change the multicast vlan on a wireless user via either a aaa attribute or Cisco AV Pair that can be returned from the radius server, in this case Cisco ISE. The WLC is a 9800 running 17.3 release code .
wireless profile policy XXXX-SSID
aaa-override
description XXXX
http-tlv-caching
multicast vlan 50
nac
radius-profiling
subscriber-policy-name BUILTIN_AUTOCONF_POLICY
vlan Test
no shutdown
I cannot find a list of aa attributes or cisco av-pairs that are supported for the 9800 in any of the online documentation.
Rich R
The aaa attributes/av-pairs documentation is practically non-existent.  It took about a month just to get a TAC engineer to understand a similar question recently and then they still couldn't find the answer even after they (sort of) understood the question.  They just kept telling us to refer to ISE documentation instead of answering the question!
Your only hope is a TAC case - but good luck with that ...
brandjoh
This information is available via the cli, try show aaa attributes and show radius table attributes.
Hope that helps.
Thanks for that @brandjoh - good to know.
That said, I don't see anything that looks like multicast vlan which is what @Sean Aindow was asking about.  Do you know whether there is any attribute for that?
Rasika Nayanajith
what is the use case? Typically multicast vlan in use when you have vlan-group (known as 'interface-group' in AireOS ) and you want to specific vlan to send multicast request instead of all the vlans sending multicast requests in that group.
I do not think there is an option to use AAA override for it
Rasika
*** Pls rate all useful responses ***
