Cisco c9105 AXW Controller
gianlucamicunco
Community Member
Hi, I have 2 9105 axw APs.
Searching on the Internet I found that 9105AWX cannot works stand-alone.
What I need to make them work? Controller
13 Replies 13
David Ritter
Level 10
Level 10
Yes.  You need a controller of some type.  I would suggest another 9k class AP in EWC mode, say a 9210AXI or cloud based 9800.  I have my one and only 9105AXW, along with the rest of the 181x wall mounts on my AIRos 5520
gianlucamicunco
Community Member
I'm new in Cisco wireless world, can you link me some resources?
Cisco catalyst 9800 wireless controller could be okay?
gianlucamicunco
Community Member
Or any inexpensive controller? My client need to have just that 2 APs
The 9800-L-C is the small version that would work.  If your customer has ESXi or Hyper-V, you can install a 9800-CL.
-Scott
gianlucamicunco
Community Member
Is AIR-CT5508-12-K9 compatible with c9105axw?
                        >Is AIR-CT5508-12-K9 compatible with c9105axw?
           - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
  No , because the 9105AXW needs at least 8.10.162.0 which the 5508 can not (or no longer) run ,
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
No, that controller is too old for the 9105. I would either go with the suggested 9800-CL if you have a system to run it, or even better, buy a 9105 (without the "W") and use it as the controller (EWC mode). That could be the simplest method.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
gianlucamicunco
Community Member
I was looking for a cheap controller. Can you help me?
                      >...I was looking for a cheap controller. Can you help me?
 The 9800-CL (cloud version) is free for download , but you will need to buy a license for the access point(s) ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
gianlucamicunco
Community Member
Or can you just explain how to choose a correct/supported one?
I read the link you posted but it's not clear to me. Thanks
The 9105W needs a controller with an up to date firmware. The 5508 is very old, same would be with the 2504. If you can get a cheap 3504, that would work but I expect it still to be more expensive than an additional 9105AXI.
I think I'll buy 9105AXI. Is there some resources to study controllers? Like compatibilities, firmware, List of outdated controllers etc.
I've read documentations on cisco website but it's very confusing.
The website will show you information on all the new 91xx access points and the new 9800 controllers.  That is where you should start, but being new, I think it would be hard for you to decide on really what you want.  This also depends on what you are trying to do and your budget, if you have VMware or Hyper-V in your environment, etc.  Just take a look at the links below to help you with the various EWC models, the smaller 9800-L controllers and the virtual 9800-CL controllers.
Cisco Embedded Wireless Controller for an AP Data Sheet - Cisco
Cisco Catalyst 9800-L Wireless Controller Data Sheet - Cisco
Cisco Catalyst 9800-CL Wireless Controller for Cloud Data Sheet - Cisco
-Scott
