04-12-2024 03:12 PM
I have a Cisco c9120axi-e access point, and I want to configure it, but the SSID is not displaying. I connected it with a router, it got an IP address, but the web interface of the access point is not accessible with its IP address.
Best regards,
04-12-2024 11:19 PM
- It can only be used in standalone mode if it is running embedded wireless controller software (=?)
M.
04-13-2024 01:42 AM - edited 04-13-2024 01:43 AM
it got an IP address - what IP it has ? from what device you try to connect to AP ?
check EWC deployment guide :
=====️ Preenayamo Vasudevam ️=====
04-13-2024 06:38 AM
I recently installed a network access point in my home network to extend my Wi-Fi coverage. I connected this access point to my main router, which also provides an internet connection, and I connected my PC to the same router.
While performing a scan of IP addresses on the network, I found that the access point had obtained the IP address 192.168.1.135. However, when I try to access this address via a web browser, I don't receive any response
04-13-2024 08:40 AM
Try using https://192.168.1.135
04-13-2024 09:14 AM
- GUI is only available if it is running embedded wireless controller software (=?)
M.
04-13-2024 11:34 AM
If you are already running embedded wireless controller software, are you able to ping the AP IP or access it via terminal, if yes try different browser, try incognito mode.
04-13-2024 02:02 PM
connect the console cable and check, also make sure you are running EWC image.
if all good you can start zero day provisioning as mentioned before post :
Day 0 – provisioning using the over-the-air setup wizard
