Cisco C9800-L-F-K9 and iPhone 12 reconnection
Wasiliy
Greetings to all,
we have a Wi-Fi system in a building based on Cisco C9800-L-F-K9 and AIR-AP1815I-R-K9 access points. Periodically one client, Apple iPhone 12, loses connection with SSID and it cannot connect. We have enabled Radioactive Trace by its MAC address. In the file, I received some messages that seem suspicious to me. Could you tell me if these messages are normal client operation, or if there is a problem at this point?
Below are some excerpts from the log files:
2021/06/01 09:20:40.166652 {wncd_x_R0-0}{1}: [sisf-packet] [17010]: (debug): RX: ARP from interface capwap_900000a2 on vlan 2504 Source MAC: 222e.72f8.a3c2 Dest MAC: ffff.ffff.ffff ARP REPLY, ARP sender MAC: 222e.72f8.a3c2 ARP target MAC: 0000.0000.0000 ARP sender IP: 10.238.40.170, ARP target IP: 10.238.40.170,
2021/06/01 09:20:58.529624 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [17010]: (info): [222e.72f8.a3c2:capwap_900000a2] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2021/06/01 09:20:58.529733 {wncd_x_R0-0}{1}: [sisf-packet] [17010]: (info): RX: DHCPv4 from interface capwap_900000a2 on vlan 2504 Src MAC: 222e.72f8.a3c2 Dst MAC: bc4a.56ed.ca61 src_ip: 10.238.40.170, dst_ip: 10.221.138.17, BOOTPREQUEST, SISF_DHCPREQUEST, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 222e.72f8.a3c2
2021/06/01 09:20:58.531026 {wncd_x_R0-0}{1}: [sisf-packet] [17010]: (info): RX: DHCPv4 from interface capwap_900000a2 on vlan 2504 Src MAC: bc4a.56ed.ca61 Dst MAC: 222e.72f8.a3c2 src_ip: 10.221.138.17, dst_ip: 10.238.40.170, BOOTPREPLY, SISF_DHCPACK, giaddr: 0.0.0.0, yiaddr: 10.238.40.170, CMAC: 222e.72f8.a3c2
2021/06/01 09:21:11.462305 {wncd_x_R0-0}{1}: [dot11-validate] [17010]: (ERR): MAC: 222e.72f8.a3c2  Validate dot11 ie for samsung payloads. Invalid ie type Received ouiType 10 Expected ouiType 34 Received oui 0x0, 0x17, 0xf2, Expected oui 0x0, 0x0, 0xf0
2021/06/01 09:21:11.462310 {wncd_x_R0-0}{1}: [dot11] [17010]: (ERR): MAC: 222e.72f8.a3c2  Dropping the disassoc or deauth request. 11w not enabled
2021/06/02 09:13:20.601847 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 EAP key M5 sent successfully
2021/06/02 09:13:20.601849 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Client key-mgmt state transition: S_PTKINITDONE -> S_REKEYNEGOTIATING
2021/06/02 09:13:21.602008 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Keymgmt: resend eapol key m5. Retrasmitting EAP key packet M5
2021/06/02 09:13:21.602099 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Client key-mgmt state transition: S_REKEYNEGOTIATING -> S_REKEYNEGOTIATING
2021/06/02 09:13:22.602502 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Keymgmt: resend eapol key m5. Retrasmitting EAP key packet M5
2021/06/02 09:13:22.602590 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Client key-mgmt state transition: S_REKEYNEGOTIATING -> S_REKEYNEGOTIATING
2021/06/02 09:13:23.603077 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (ERR): MAC: 222e.72f8.a3c2 Keymgmt: Failed to eapol key m5 retrasmit failure. Max retries for M5 over
2021/06/02 09:13:23.603081 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Keymgmt: eapol key failure. Sending client key exchange failure to auth fsm,reason code: 16
2021/06/02 09:13:23.603094 {wncd_x_R0-0}{1}: [client-keymgmt] [17010]: (info): MAC: 222e.72f8.a3c2 Client key-mgmt state transition: S_REKEYNEGOTIATING -> S_PTKINITDONE
2021/06/02 09:13:23.603145 {wncd_x_R0-0}{1}: [client-auth] [17010]: (info): MAC: 222e.72f8.a3c2 Client auth-interface state transition: S_AUTHIF_PSK_AUTH_DONE -> S_AUTHIF_PSK_AUTH_DONE
2021/06/02 09:13:23.603159 {wncd_x_R0-0}{1}: [client-orch-sm] [17010]: (note): MAC: 222e.72f8.a3c2 Client move to idle state, delete reason: CO_CLIENT_DELETE_REASON_GROUP_KEY_UPDATE_TIMEOUT, BSSID MAC: ac4a.5645.a08c, WTP MAC: ac4a.5645.a080
2021/06/02 09:13:23.603257 {wncd_x_R0-0}{1}: [client-orch-state] [17010]: (note): MAC: 222e.72f8.a3c2 Client state transition: S_CO_RUN -> S_CO_IDLE
2021/06/02 09:13:33.603809 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [17010]: (ERR): 222e.72f8.a3c2CLIENT_STAGE_TIMEOUT State = IDLE, WLAN profile = TatAIS_INET, Policy profile = TatAIS_INET, AP name = TN_2_AP_8_fl_4
2021/06/02 09:13:33.603810 {wncd_x_R0-0}{1}: [client-orch-sm] [17010]: (info): MAC: 222e.72f8.a3c2 Deleting the client, reason: 16, CO_CLIENT_DELETE_REASON_GROUP_KEY_UPDATE_TIMEOUT, Client state S_CO_IDLE
2021/06/02 09:13:33.603861 {wncd_x_R0-0}{1}: [client-orch-sm] [17010]: (note): MAC: 222e.72f8.a3c2 Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_GROUP_KEY_UPDATE_TIMEOUT, fsm-state transition 82|8a|13|17|18|28|33|42|44|46|48|4d|5c|5e|7f|82|8a|13|17|18|28|33|42|44|46|48|4d|5c|5e|7f|26|55|
5 Replies 5
marce1000
 - Check if resolving-reply from this thread can help :
         https://community.cisco.com/t5/wireless/catalyst-9800-cl-client-losing-connectivity/td-p/4269460
 M.
Wasiliy
marce1000
Thanks for the answer.
Now we are collecting statistics on a problem client using a radioactive trace.
We will take note of your information.
Did you find a resolution for this? I am experiencing a similar issue where iPhones will get a blank white page instead the ISE Guest Portal. See the similar logs below.
2021/10/29 12:27:10.139371 {wncd_x_R0-4}{1}: [dot11-validate] [26555]: (ERR): MAC: fc4e.a4c3.9af3 Validate dot11 ie for samsung payloads. Invalid ie type Received ouiType 10 Expected ouiType 34 Received oui 0x0, 0x17, 0xf2, Expected oui 0x0, 0x0, 0xf0
2021/10/29 12:27:10.139588 {wncd_x_R0-4}{1}: [dot11] [26555]: (ERR): MAC: fc4e.a4c3.9af3 Dropping the disassoc or deauth request. 11w not enabled
Our problem was solved after upgrading the software controller and access points to version 17.3.4.
Arshad Safrulla
disable PMF (Protected Management Frame)
disable or enable fast transition, don't use adaptive. If you are using enabled use only over the air FT.
