11-01-2021 09:28 AM - edited 11-01-2021 09:32 AM
Hello All,
I try to add ospf network to my router (R1), so I added new Routing networks.
However, even though I configured correct routing networks and wildcard mask, it does not applied to other router (R2).
I am not able to find other reason.
Do you think this issue related to advertisement mode? like transparent mode. Currently I have no access right about R2 so I am waiting the answer from the engineer who can check the R2.
In the meantime, is there anything I need to check from my side (R1)?
I found that [sh ip protocol] command:
- Outgoing update filter list for all interfaces is not set
- Incoming update filter list for all interfaces is not set
Do you think if I configure update filter correctly, R2 can be applied my updated networks?
**Your comments could be a great advice for me. Thank you.
11-01-2021 09:55 AM
The Filter is to filter the networks, nothing to do wioth your problem you mentioned ?
If possible post the bit of the configuration what you configured. and check the below :
1. Do you have oispf neighbourship ?
2. are they in same area ?
3. Hope they not have duplicate IP address space ?
11-01-2021 10:04 AM
Thanks for replying.
Okay so incoming/outgoing filter is about giving conditions like acl, correct?
I have double checked configuration what you've asked and the there is no mis-configuration on R1 router.
- ospf has same area / backup designated router, interface address are correctly setup / No duplicate IP ranges.
Probably I need to wait engineer's reply who can check R2 router..
Thank you..!
