06-02-2025 06:21 PM
Is the column of wireless client monitor below can be customized? I need to showing the client devices name where now i only can see the name if we click on each client. Tyr to exporting the data but the device name is not showing.
06-02-2025 06:44 PM
sh wireless client summary detail
Is the query found in the output above?
06-03-2025 12:02 AM
not showing even using that command
06-03-2025 01:06 AM
Then it will not show in GUI no matter what.
06-04-2025 07:49 AM
I think you will have to run a few scripts if you want to grab that data. You would need the mac address list and then use that list to get the details and parse that into your db or spreadsheet.
show wireless client mac-address <mac-address> detail | in Device Name
