Cisco Catalyst 9800-40 Wireless Controller Mobility Setup
reon.boshoff1
Community Member
Trying to set up a peer connection from 9800 wlc to 5508 wlc witch is my Anchor WLC.
Control and data path not comming up
 - The 5508 is running 8.2.130.0 which can't work ; you needhttps://software.cisco.com/download/specialrelease/62d6c72703b966f3de6efe95e19bdfef
            as explained in https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#toc-hId--68356249
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
  - What software versions are the controllers on ; note https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller-aireos_ircm_dg.html
       >...Supported Cisco AireOS Wireless Controllers running Cisco AireOS 8.5 IRCM supported image based on the 8.5 Maintenance Release software
 M.
reon.boshoff1
Community Member
5508 WLC
9800
 M.
