WLC9800 - AP join test with aaa
eeebbunee
Level 3
Level 3
Hello Professionals,
I'm on testing using AP-2800 Series and WLC9800, and would like to check my scenario is correct.
Here's my test lab>
AP-A: 2802I , Seral#aabbcc
AP-B: 2802I, Serial#112233
WLC9800 - AAA Method List : AP_Auth
                - AAA Advance: AP Policy - Authorize APs against Serial Number (List: AP_Auth)
                - AAA Advance: Device Authentication 'Serial Number' : aabbcc is added.
When I test with AP-A, I was able to see the ap status from the controller.
 - Before I put serial number: AP status-Not join, Reason: Auth failed
 - After I put serial number: AP status-Join
(CLI: show wireless ap stats ap join sum)
However, when I test with AP-B, I can't see the AP status at all.
Number of APs: 0
Between WLC9800 - AP-B, ping is able.
WLC9800 does not recognize AP-B right now? I was expected to see the list as 'Not Join' status.
When I check
 - show wireless stats ap mac 'AP-B'
 - show wireless stats ap discovery
Nothing is shown from the WLC9800.
From the AP-B side, AP is keep sending 'Discovery Request' to WLC9800.
Why am I got different situation with same series of AP?
Thank you for your comments.
marce1000
  - Have a general and overall checkup of the 9800 controller with the CLI command : show tech wireless ; feed the output into : https://cway.cisco.com/wireless-config-analyzer/
    You can further analyze AP joining  issues with : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800APJoin
 M;
balaji.bandi
i would check the SN again and make sure it was correct. connect to AP console and post complete logs, also check the Logs in WLC.
i am sure you following below document (just reference :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213916-catalyst-9800-wireless-controllers-ap-au.html
BB
