Cisco Catalyst Wireless Application for Android
souravkakkar
Frequent Visitor
Frequent Visitor
Hi Team,
I am trying to download the Cisco Catalyst Wireless App on my android phone (Android Version 12). However, the Google Play Store suggests the following and doesn’t allow me to install the app:
“This app isn’t available for your device because it was made for an older version of Android”.
Whereas the user guide for the app suggests that it should be available for Android version 8 onward:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/mob-app/user-guide/cisco_catalyst_wireless_app_ug_12/overview_of_the_mobile_app.html
Does anyone know if the app is still available on Android and if yes, where can I download it? Thanks.
S
Rich R
The release notes clearly state: Android 8.0 (Oreo) to Android 11
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/mob-app/rel-notes/cisco_catalyst_wireless_app_rn_12.html#id_136199
So if you want them to update it for new versions you'll have to open a TAC case and get an enhancement request raised, with a supporting business case from your account team.  Given that they haven't updated the app in over 2 years I think they're more likely to end of life it than update it.
That said - I was able to install it by going to the play store on Windows while logged in to my Google account:
https://play.google.com/store/apps/details?id=com.cisco.catalystwireless&hl=en_US&pli=1
Then select the install option there (which allowed me to select my Android 14 phone) and after that it showed it in Play store on the phone and allowed me to install it!
Under the * Help there is a Contact Us option so you could also submit feedback there.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Rich R
Thanks Rich. The application is available after I tried the suggestion above.
