Cisco Catalyst Wireless Beta Programs
Sudhagar Singh
Cisco Wireless Beta team would like to invite you to participate in following EFT programs
Beta ProgramSignup FormEFT Dates
Cisco Catalyst 9800 IOSXE 26.2.1 EFT Program
http://cs.co/2621EFT-Signup
Start Date: 4th June 2026
End Date: 31st July 2026
Cisco Catalyst 9800 IOSXE 26.1.2 EFT Program
http://cs.co/2612-EFT-Signup
Start Date: 22nd May 2026
End Date: 15th July 2026
Cisco AP Auto Locate on Catalyst Center Beta Program
http://cs.co/AP-Auto-Locate-EFT-Signup
End Date: 31st December 2026
Hi @RichRich , @Mark Elsen
Thanks for bringing this to our notice. I have corrected the link updated the same row in the table. Can you please try now?
-Regards,
Sudhagar Singh
9 Replies 9
train00wreck
Level 3
Level 3
Just tried to do this, it won't let me proceed without entering in a bunch of Meraki info. I don't use Meraki ,just 9120/9136 APs. i guess that means I can't sign up?
Hi @train00wreck
Thanks for your interest in the Beta program.
The Meraki info is optional. You can skip that.
Please let me know if you are still stuck.
@Sudhagar Singh - for the section Meraki Info, there are many requires fields that cannot be skipped (E.g. URL dashboard, Meraki Dashboard Org. ID, etc.), please see attached! For customers that do not have Meraki, how do we skip that part?
luisarel
Is there a mailer to stay tune on upcoming beta programs ?
@luisarel you just have to subscribe to this thread <wink>
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Rich R
@Sudhagar Singh the link for the 26.2.1 EFT says Entity does not exist on Stomio.
Please confirm correct URL?
Edit: confirmed working now - thanks 👍
 - @Rich R      @Sudhagar Singh            Confirmed :
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
-Regards,
Sudhagar Singh
 - @Sudhagar Singh   Yes! It works now
 Mark
