Cisco Controller enable session timeout
wjsenqkf2
Hello, everyone.
I have a question. Please help me.
I am doing user authentication with 802.1x on a specific WLAN.
And there is'enable session timeout' option in WLAN->Advanced.
This option is the timeout value for re-authentication of the wireless device.
Here I want to know.
If set to 60 minutes, will the wireless device re-authenticate after 60 minutes?
If the traffic continues to occur on the wireless device, does it require re-authentication?
I would like to know if the wireless device needs to be re-authenticated even if traffic is flowing.
Thanks.
2 Accepted Solutions
Grendizer
Even so, the client has to reauth every 60 minutes but this will be done in the background by the device without interaction from the user.
I have not enabled session timeout. Not selecting the Enable Session Timeout check box is equal to setting it to 0, which is the maximum value for a session time out for each session type. If you configure a session-timeout of 0, it means 86400 seconds for 802.1X(EAP).
You should still test and select the timeout value which is optimal for your environment.
7 Replies 7
Grendizer
balajiviswanathmohan
Frequent Visitor
Frequent Visitor
Hi, Please see my comments below.
If set to 60 minutes, will the wireless device re-authenticate after 60 minutes? - Yes it has to. The session timeout is the maximum time for a client session to remain active before requiring re-authorization.
If the traffic continues to occur on the wireless device, does it require re-authentication? - Yes. It happens in the background for 802.1X. If you were using Web-Auth, it would prompt the user to login into the captive portal to be authenticated again.
I would like to know if the wireless device needs to be re-authenticated even if traffic is flowing. - Yes, it has to re-authenticate even when there is active traffic.
What is the recommended value for session timeout? I use Windows 10 pc and Apple mac book.
Ok.
Many thanks.
You are Welcome.
