Cisco E900 router WiFi connection problem.
raaghu.anand
I own a E900 series router, recently the system (Desktop) was fried by short circuit which was connected to the router too.
Motherboards inbuilt  lan connector was affected but not the router.
Even after the short circuit incident I was able able to use (in mobile) wifi for 3days but later it only signaled wifi connection but no internet.
Router switches on and Green lights are on indicating internet but not able to access internet through WiFi.
Please help me in finding out the problem and solving it too.
Raghu
Saurav Lodh
Level 7
Level 7
https://community.linksys.com/t5/Wireless-Routers/Linksys-E900-Wireless-N300-Router-connectivity-issue/td-p/575850
Hi Saurav,
Thanks for the reply.
I tried doing those steps explained in the link you have mentioned before itself but nothings working.
Tried resetting the router and connecting the chords the way it as to be but still no WiFi!
As I mentioned before, it was working properly before the short circuit incident, now it as stopped.
Is there any way of getting it repaired because the green lights are still on and the signal of WiFi is seen in other devices (mobile) but internet is not connected.
Thanks again,
Raghu
