Slow DHCP exchange over Wireless (4507R+E/SUP8E)
cnegrete
Hi everyone.
I have a small issue with DHCP over Wireless and I need some insight.
Basically I have 8 SSID's, each on a different VLAN and Wireless Channel (they don't interfere with each other, they're spread over the 2.4 and 5GHz spectrums).  I do have as well 8 DHCP scopes on the switch (it's the same switch who does the WLC function with the SUP8E card, just like the 3760 switches).
If I connect a machine over UTP, the switch assigns an IP address within 3 seconds, but if I do it over the Wireless network, it takes over 40 seconds.
I checked with wireshark and my machine sends 6 DHCP requests before the switch answers, it's just as if the switch never gets the DHCP requests.  The same goes on the other direction, the switch says it has assigned the IP to the machine, but it takes another 30 seconds for the machine to get the response.  I'm suspecting there's too much traffic in the WLAN for the DHCP packets to arrive (and they're UDP so..). By the way, we have 30 clients on each WLAN at the same time, some get their ip quickly, but others are lagging behind, sometimes more than a minute. Sometimes even windows gives up and assigns a 169.x.x.x address by itself.
Is there a way to create a QoS setting that would send the DHCP packets with top priority on both directions?
Thanks for any ideas you might have.
I'm attaching the (almost full) config file.
5 Replies 5
Freerk Terpstra
Level 7
Level 7
I checked your configuration and I have the following suggestions:
1. Go to rapid spanning-tree, because rapid is always better (right?)
spanning-tree mode rapid-pvst
2. Go to a DHCP lease time of 8 hours instant of 5 minutes
ip dhcp pool xyz
 lease 0 8
3. Migrate from WEP to at least an PSK WPA2 AES (no tkip) configuration, dot1X is even better.
4. Go back to an absolute maximum of 4 SSID's, this should be possible for every environment with dot1x or ISE and AAA override. Every SSID has it's beacons and you are probably not the only one using 802.11 technology in your neighborhood.
If you are still having problems with multiple clients, go back to one SSID with no encryption at all. Than make changes step by step and see what is causing the latency.
Please rate useful posts :-)
1. Does it matter on Wireless?
2. The pool is set that way because it's a tablet activation area. The tablets are connected no more than 5 minutes at a time, and we don't want to exhaust the 250 hosts pool.
3. We could do that, but the tablets are already configured and the image takes time be rebuilt. I might try this one.
4. The SSIDs are spread over different 5Ghz channels so that shouldn't matter.
Let's see which options I can try.
I may even begin with the no encryption one first.
Any other ideas?  Because once the tablets get their IP address, the activation process goes smoothly.
The suggestions are based on my own personal experiences and best practices. I never saw an client connecting for a that short amount of time. Don't forget that conform the RFC's clients should renew their lease when they are at the half of the given lease. I don't know the details and scale about your project but I should start with a little bigger VLAN and just one SSID.
You can also run some "debug ip dhcp server" commands on the switch to see when the discovery messages are actually reaching the switch. If you want to you can also get some more information for specific one wireless client with the "debug client mac-address aa:aa:aa:aa:aa:aa" command.
Well, it seems that the WPA2/AES setting did the trick, but not for the encryption itself, but the fact that the tablets began connecting with 802.11n instead of g/a. That made a huge difference in the response times.
We're still monitoring, but the DHCP responses were drastically reduced, from about 90 seconds average to less than 20 all the time.
The only way to reach 802.11n speeds is without encryption or WPA2 AES, so that make sense. I still recommend you looking into the other things as well and maybe make a trace of the wireless traffic as well.
