Cisco EWC Network (Maximum APs?)
matthewhongkong
Community Member
Hi all,
I am working on a Network company in HK. Since the delivery schedule is extended, I am thinking of another method for client. There should have 300+ APs and Cisco C9800 Controller but the controller cannot be shipped on time. So, I would like to use Cisco Catalyst 9120 for Cisco EWC Network.
Now there is two problem,
1. Is there any solution can host 300+ APs in one EWC?
2. After I export EWC configuration, Can I insert to C9800 Controller directly?
Thanks a lot.
Leo Laohoo
Definitely not!  The highest is 100 APs (Cisco Mobility Express Scale Limits).
How about the Q2? Is the configuration are the same or just similar ?
Thanks a lot.
eWLC config is only for eWLC.
Besides, eWLC is a "diet C0ke" in features and functionality of a full-blown WLC.  The config of either platform can never be compatible.
Actually a lot of the wireless config is portable as they're both built on the same IOS-XE code.  But there are some differences between the 2 as well.  So some of the config you could copy/paste between them and the rest you would need to configure from scratch.  Convert one of your APs and play with it so you can see for yourself.
What about using 9800-CL (on Vmware ESX for example) as long as you don't need to centrally switch the traffic.  You can fire that up instantly, it will just work, up to 6000 APs.  Max central switching throughput on standard server = 2.1Gbps or use flex local switching.  You can achieve 5Gbps central switching with SR-IOV with the right network adapters in the server but that might take as long to source.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-cloud-wirel-data-sheet-ctp-en.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
