Cisco Guest Access Using WLC with Anchor setup client connection speed?
marktrible
I currently have Guest wireless working and  the setup is with Guest anchors.  Clients can only connect at 54Mbps.  Is it possible to get faster connection speeds?   My setup is just like what is shown in the "Cisco Guest Access Using WLC with Anchor setup – Release 7.0" document
balaji.bandi
what kind of AP Models and WLC model you using ?
BB
Controllers all are on 8.5.131 code.  I have 100 controllers  2504, 5508, and 5520.
The two Guest Anchors are 5508 on 8.5.131 code.
The AP's are a mix of AIR-AP3502I-A-K9 AIR-CAP3602I-A-K9, AIR-CAP2702I-A-K9, AIR-CAP2702I-B-K9, AIR-AP2802I-B-K9, and AIR-CAP2602I-A-K9 for a total of  around 5,050.
