Cisco IR829 DHCP Question
AndrewGibbons8
Hello everyone, I have a Cisco IR829 that I'm trying to connect the shown network devices, but I've run into an issue. The Laptop, Switch (3560), and AP (1562e), all connect just fine and can receive DHCP from the Switch; however, when I try to connect wirelessly to the AP from the IR829 it doesn't get a DHCP Address. Any advice on how I could fix that? Let me know what other info, configs, etc you'd like to see if necessary, and thanks ahead of time.IR829.jpg
Andy
patoberli
In this case the configuration of the IR829 would be useful (remove passwords first).
If you connect a laptop wireless to the AP, will that work?
Hi patoberli,
I work with Andy on this project and would like to share with you our IR 829 AP config below:
ap#sh run
Building configuration...
Current configuration : 3352 bytes
! Last configuration change at 00:25:34 UTC Mon Mar 1 1993 by cisco
version 15.3
no service pad
hostname ap
logging rate-limit console 9
enable secret 5 $1$Zm0/$KRuZmWQ/ZoCI6WlXTfwD3.
no aaa new-model
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 ant-band-mode dual
dot11 ssid TestCisco1560
vlan 1
authentication open
no ipv6 cef
username cisco privilege 15 secret 5 $1$Un8z$OpkcnDFYjdmEWwLzDLXW01
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid TestCisco1560
antenna gain 0
station-role non-root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
no bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
ip address dhcp client-id Dot11Radio0
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
mac-address a093.5131.d712
no ip route-cache
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
Laptop receives ip address through DHCP with no issues from Cisco1562e AP.
But IR829 AP can't receive ip address through DHCP for some reasons. We can see that Cisco ir829 AP associated and established with Cisco 1562e AP but cant receive ip address.
This is the log message that we get:
 *Mar 1 02:11:30.687: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
*Mar 1 02:11:31.663: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP AP6C31.0EC7.C0B 3c51.0ef9.4b00 [None]
*Mar 1 02:12:50.799: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
*Mar 1 02:12:52.491: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP AP6C31.0EC7.C0B 3c51.0ef9.4b00 [None]
*Mar 1 02:14:11.783: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
*Mar 1 02:14:19.603: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP AP6C31.0EC7.C0B 3c51.0ef9.4b00 [None]
*Mar 1 02:15:38.983: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Received disassociate (1) failure
*Mar 1 02:15:39.783: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP AP6C31.0EC7.C0B 3c51.0ef9.4b00 [None]
Thank you
I'm not sure, but I think your IR829 isn't successfully connecting as a wireless client to the AP. I think you are missing some configurations on the Dot0.1 for the encryption of the wireless link.
Maybe this part helps: https://community.cisco.com/t5/wireless-mobility-documents/autonomous-ap-and-bridge-basic-configuration-template/ta-p/3112198
You can also run "debug ... " commands on the IR, but I haven't used them in years and don't remember the exact commands anymore. But I think "debug ip dhcp ?" should show some information.
