Cisco Mesh Issue - expanding mesh to inside a 'Faraday cage'
adamcollyer1
I currently have two AIR-CAP3602I-E-K9 that are set up in 'bridge+flex' mode so our users can screencast seamlessly whilst walking between the areas covered by the two access points. We also need coverage in another room which is essentially a faraday cage (needs to remain this way so RFID tags external to the room cannot be read by a reader within the room and vice versa)
So is there a way that I could include another AIR-CAP3602I-E-K9 with the current mesh, I'm looking at either setting it up as another RAP or seeing if there is a way to incorporate the mesh over ethernet if anyone can give me any pointers it would be appreciated.
The screencast needs to be seamless as it is being used to demo some of our products in a mock up shop.
Joe
pieterh
you can configure one AP as mesh + WGB  and connect the LAN segment to an AP inside the cage?
