inquiry
edsabado
Community Member
i have my cisco access point 1130AG ip address assigned by my DHCP but i cannot access the page setting when i enter it on the browser url address. It says page cannot display
pieterh
is this a stand-alone AP?
1) if it is stand-alone then you need to give more detailed error message.
It may be your browser security setting prevent the applets loaded from the AP to run.
2) if not (your environment is controller based) than you first need to enable the web access to the AP  from the controller first!
3) the AP image is controller based, but you do not have a controller, then you need to load stand-alone image on the AP.
connect a serial console to the AP and inspect the output
