Cisco Mobility Express Bundle conversion
dohnesor
I have a question regarding the Cisco Mobility Express Bundle (not the appliance-less Mobility Express on 1800 series AP). When the bundle is purchased, is the software on the 2500 WLC a cut down version with the Day 0 Setup Wizard and new dashboard or is it the full version of software that would be the same when you buy a standalone 2500?
Sandeep Choudhary
HI,
As per my knowledge, it will be with full version of software that would be the same when you buy a standalone 2500.
Reagrds
Dont forget to rate helpful posts
Sandeep Choudhary
HI,
Reagrds
Thanks Sandeep, I have marked you reply as the answer.
