Cisco Mobility Express setup problems
FabianK
Visitor
Hi all,
I recently bought a aironet 1815i air-ap1815i-e-k9c. I made sure it receives enough power and it boots up nice.
I can connect to the CiscoAirProvision SSID and input my settings but after this the AP reboots and stays in the join/ discovery mode (LED blinks red, amber,green) it has been doing this for a long time 30+ minutes. I tried restring to factory settings but still the same result.
Does anyone know how to fix this?
thanks in advanced.
I mentioned that i made sure it is not a power issue i use a AIR-PWRINJ6= PoE injector.
I turned out to be a ip issue. I set a static ip in my router for the ap but i set the same ip as management ip.
After changing the ip in my router it worked.
Edwin Portillo
Hi @FabianK
The user manual was reviewed, there are some considerations that must be taken into account for the operation, no doubt according to the color code indicates that it is a General warning; insufficient inline power, since this device is made to work like this:
See the following:
link: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1815/quick/guide/ap1815igetstart.pdf
