Cisco PLAR between two different networks
Ng Tian Sheng
Hi All,
I need help in setting up the phones communication (PLAR) between two different networks.
I have Network A and Network B, both networks are totally separated networks and they do not have any connectivity between each other. What I want to do is to configure connection PLAR so that when I pick up the phone in Network A, phone at Network B will ring automatically.
If I wish to connect a direct RJ11 cable between one router (FXO) at Network A and another router (FXO) at Network B, is it possible to make sure the call can be placed? If yes, how to configure this setup?
Thanks.
Joshuabowers
Do you have POTS dial peer pointing to the next router.
