Cisco Prime Express Plus 2.2 running in VM
IamDaMayor
Cisco Prime Express Plus 2.2 running in VM as we can't even login to it at the moment.
First make sure the VM you have is in complience with Cisco requirements:
Table 1 Prime Infrastructure Minimum Server Requirements
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/quickstart/guide/cpi_qsg.html
-If I helped you somehow, please, rate it as useful.-
